Question about Zenith D60WLCD Television
My lamp inicator flashes red after a minute or two and the television turns off. I've replaced the bulb and it still does it. Zenith D60WLCD ??
  • eforren1 Jun 26, 2009
    There is a temperature light and a lamp light.
    Only the lamp light flashes red. Accordking to the manual,
    this means something in or around the lamp is not working
    properly.
  • Zenith Master
  • 3,866 Answers
Okay this tells me something is getting hot and forced shutdown so I would check and see if fans are obstucted, and there RPMs are up to par.
But when in doubt always call the manufacture as they know to whom to take it to for a repair.
Something is causeing this to turn off and its mostlikly the heat,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 26, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Jun 26, 2009
    did you replace the balast?
I have a Zenith D60WLCD, I have replaced the lamp and it still will not power up. I there something I need to reset.
You need to reset the lamp counter if it reaches 16,000 hours. The tv will not turn on once this limit is reached. With the tv remote, and the tv off, push the ? Button on the remote, then 9876, then push the enter button. The three lights on the front panel will flash indicating the counter has reset.
Dec 11, 2012 | Zenith D60WLCD Television
How do I reset the replace lamp indicator light on my zenith d60wlcd tv ?
Aug 30, 2012 | Zenith D60WLCD Television
I need to reset lamp timer on zenith d60wlcd
Jun 29, 2012 | Zenith D60WLCD Television
Need to reset lamp timer on zenith d60wlcd please help
With the TV off, use the TV remote to press the "?" Button and then enter 9876 and then the enter button. The three lights on the front panel will flash, indicating the lamp counter is reset.
Oct 31, 2011 | Zenith D60WLCD Television
MY ZENITH D60WLCD PICTURE IS VERY DIM. i HAVE REPLACED THE BULB BUT IT IS STILL DIM. NOW WHAT?
Have you adjusted the brightness settings or any other settings to change the picture?
Feb 28, 2011 | Zenith D60WLCD Television
TV turns off after about a minute flashing red light on lamp indi
your tv is talking to you basically, is telling you that the lamp has to be replaced. this is a common problem with this dlp tvs, when the lamp is bad the shuts off within minutes, so just replace the lamp my friend.
May 26, 2009 | Zenith D60WLCD Television
Zenith D60WLCD
Long story short: The blue fog problse is the light engine. Specificaly, the filter for the blue LCD gets to hot and over time starts to burn up and disinigrate. (I just tore my set apart thinking maybe it was the blue panel and found this was indeed the culprit for this problem). As far as a solution? You will either need to replace the light engine (expensive) or replace the light filter which means tearing the thing completely apart. then there is the problem of where to get a replacement filter. Does ANYONE know where? As far as the lamp goes, might be time to replace it. You might be better off just getting rid of that TV and get a new one.
Jul 18, 2008 | Zenith D60WLCD Television
Zenith e44w48lcd Won't turn on
need manuals for model z32Lc2d ser719192169807
Jan 05, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Zenith D60WLCD LAMP INDICATOR START BLINKING IN RED AND TV GO OFF
This sounds like a lamp failure. See your owners manual for instructions on replacing the lamp.
Nov 07, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith D60WLCD Television Logo
226 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
