Question about Symbol MCL Designer (SW-33452-05) for PC
Downloading new program to scanner
I must be missing something here: I've just finished configuring a new program for my phaser p360 and I can't for the life of me figure out why it won't download to the scanner. I tried going to the system menu, going through option 1, sub option 0 and then clicking the download button on the GUI, but it keeps telling me it can't communicate with the terminal. So I check the connection and try again, even opening LinkLite to see if it's still working. When I tried to download it then, it said the terminal was in use and to try again after shutting down LinkLite. I did so and it said it couldn't communicate. I'm at a loss!
    Problem Solver:
  • 5 Answers
Re: downloading new program to scanner - Symbol MCL Designer (SW-33452-05) for PC Compilers & Programming Tools
You are the beast
Posted on Dec 18, 2007
0 characters
3 Points
My son passed on to me his computer as he just purchased a new one, Everything was going ok but I deleted a LOT of programmes he had & now I've no sound on my microsoft life cam? I'm about to...
If your sound is working everywhere but not in the webcam, check the settings of your webcam to see if microphone is disabled. Reinstall microsoft life cam software if you cannot make it working. If you don't have the software, go here to download it
Jun 19, 2011 | Sun Compilers & Programming Tools
Computer Tips: Open Office 2007 Files into Office 2003
How to open office 2007 files into Office 2003?
Today tip will help you to resolve the compatibility issues between the Office 2003 and Office 2007. Because all programs in office 2003 used the old file extensions for its different programs. For example Word 2003 saved files with extension .doc, Excel 2003 with .xls and PowerPoint with .ppt. but on the other office 2007 used the new file extensions for its different programs. For example Word 2007 saved files with extension .docx, Excel 2007 with .xlsx and PowerPoint with .pptx. Now the problem is that when you will try to open office 2007 files into office 2003 and you will not open the file due to compatibility issues between both office versions. Microsoft provides a free compatibility pack to convert office 2007 documents to the office 2003 format. There are many third party free converter are available but here we are using Microsoft office compatibility pack.
Follow the given steps to download free Microsoft compatibility pack and install it.
To use this feature, you will need to be logged into your computer with administrative rights.
Visit the following link to download the Microsoft compatibility pack:
When you have downloaded the file, double click on FileFormatConverter.exe file to start the installation.
7154964.pngNow here it’s simply a case of pretending you’ve read the license terms and clicking continue.
Now click on OK button to complete the installation.
on Mar 08, 2010 | Compilers & Programming Tools
The side of the traingle is 4 and the output is * ** *** **** *****
import java.util.*;
public class test {
static Scanner scan = new Scanner(; public static void main(String[] args) {
int mark = scan.nextInt();
for(int i=0; i< mark; i++){ for(int j=0;j<=i;j++) System.out.print("*"); System.out.println(); } } }
Dec 04, 2010 | Sun Java Programming Language (cdj-275)
I am missing some files and can not uninstall program to reinstall. I go to add and remove programs. I am trying to reinstall the program but it tells me I already have installed it
Try going to the program's directory and run the uninstall from there. Your program is likely at c:\program files\<program> where <program> is the name of the program or the manufacturer of the program. Try executing the file 'uninstall'. It might do better.
If it doesn't work any better than add/remove programs, you may have to become a bit more creative.
May 25, 2010 | Microsoft Compilers & Programming Tools
Monitor syncmaster samsung 940 BF becomes black after a few sec.
Try to boot the system with safe mode and check whether you are getting display. if yes, need to download latest driver for display card. if No, then check the monitor cable was properly connected or monitor may faulty. Replace/repair the same will solve your problem.
Also check the DPI and resolution configured in display properties.
Revert back for more clarifications or assistance required.
Dec 12, 2009 | Compilers & Programming Tools
My computer said that my system needs modifing before i can install my game
check the minimal configuration of that game and make sure u have everything mentioned there. if not u have to install those missing hardwares.
Oct 23, 2009 | Compilers & Programming Tools
I want to read text file which is located in c drive using java code can anybody help me out
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
if ( scanner.hasNext() ){
String name =;
String value =;
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
private final File fFile;
private static void log(Object aObject){
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
Jun 22, 2009 | Sun Java Programming Language (cdj-275)
Compilers & Programming Tools Logo
161 people viewed this question
Top Symbol Compilers & Programming Tools Experts
Robin Hill
Robin Hill
Are you a Symbol Compiler and Programming Tool Expert? Answer questions, earn points and help others
