Question about Bose Wave Radio
All of the bose radio light settings are flashing at the same time. They flicker and flash changes rapidly.
  • 22 Answers
Sounds like a power regulator problem. Check for proper voltages, and esp on +10V regulator IC.
Posted on Jun 27, 2009
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
Canon 430ex ii seems to flicker rapidly sometimes before taking pictures
Yes it is. The system is simply measuring the flash to meter the exposure.
Dec 29, 2013 | Canon Speedlite 430EX TTL Flash
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
Oct 14, 2009 | Bose Wave Radio
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
2001 Grand Caravan Radio Stopped working
Chances are the radio has an internl issue and requires replacement. The EQ draws power and inputs from the radio. A radio exchange is an easy process if you decide to put the sme radio back into your vehicle. Contact me if you need direction.
Dec 06, 2008 | 2001 Dodge Caravan
Resetting clock
Press the SET button until you cycle through the alarms and the Colons on the time start to flash. use the right and left arrows from the CD buttons to adjust time; After time is set; press the SET button. Be careful to not fat finger and hit the CD button when pressing the SET buttons. That will turn on the AWFUL NAP timer. That's another headache.
. Stop the Nap alarm Press NAP to start NAP flashing. Press and hold NAP to cancel the nap setting. If this does not work; try again. It seems to take me a time or 2 to get it to work.
Feb 04, 2008 | GE 74801 Clock Radio
How to set clock....
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf Hold down either Time < or Time > or press either button twice in a row... clock should start flashing
Nov 13, 2006 | Bose 36037 Remote Control
Bose Wave Radio Logo
153 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
