Question about Philips DVDR3380/05 DVD Recorder
Sound Hello could you help me i have a a philipsdvdr 3305 .i cant get any sound from any of the inputs video is ok .what have i done wrong.
  • 34 Answers
Re: sound
What is the dvd connectected to and how/what have you used to connect it mate
Posted on Nov 05, 2007
0 characters
3 Points
Video Does not work on New Magnavox TV
Hi, it sounds like your problem is that you've selected the wrong "video input" for your DVD player. Your new television most likely has at least 3-4 (sometimes 6-7) different inputs for video. With your DVD player connected and turned on, press the "Source" button on your TV to cycle through the different inputs. Be sure to wait 2-4 seconds between selections to give your TV enough time to switch inputs. If your DVD player has "color coded" output cables, it's most likely a "component" video connection. See if one of your video inputs on the TV is called "Component". Some other video types are Video, DTV, HDMI, SVideo, Component, Composite, RGB, PC Input, etc...
Jul 24, 2013 | Sylvania SDVD7014BJ 7 in. Portable DVD...
I load the disc in my player, and I get audio, but I get no picture. What am I doing wrong?
Hello sir in which player are u trying to play it ??? Whats the video format ???
Mar 13, 2008 | DVD & Blu-Ray Players
I cant get a picture only sound not sure its in the right plug?
if your tv and dvd player are good yes might be you have a wrong connection. this is how a proper connection between your tv and dvd player.
  1. first step in connecting a dvd player to a tv unit is determined what kind of connection you want to make, this usually determined to the outputs and inputs available on the dvd player and tv unit.
  2. if you are using a plasma or a lcd tv usually the inputs are: composite inputs- lets you connect a component source like a dvd, vcr, and laser disc. component inputs - lets you connect another component source such as a dvd player. DVI-HDTV - lets you connect an HD receiver with a DVI output.
  3. for example if you select the composite input what you need is a RCA plug which usually a 3 color plug.this picture is an example of commercial rca plug which usually the color yellow use for video and the red and white color for audio.vinceisaac.jpg.
  4. this is how you will connect those wire into your dvd player and tv unit.look for the component output jack of your dvd player .this picture is a sample of component output jack the color may vary depending tovinceisaac_0.jpgkind of brand or dvd player do you have.
  5. now get your RCA plug then the yellow plug insert it to the Y or video out the red and white plug insert it to the left and right AUDIO out of your dvd player.
  6. now look for the composite inputs jack of your TV unit then get the other end of RCA plug. the yellow plug must be insert it to the V label for video the red and white plug into L/R label which mean for audio input.
  7. after you connect the 3 wires re check all the connections make sure the RCA plug is good and properly inserted to avoid loose contact which can affect the picture and sound quality.
  8. now turn on your dvd player and tv unit.
  9. make sure your tv unit is set to right input you want to use like for example you are using the video 1 input, you need to set to the remote controller into video 1 so that your dvd player must be recognized by your tv. enjoy watching i hope it will help you thanks for choosing fixya as your solution to fix you problem good luck.
May 26, 2011 | Apex Digital DVD & Blu-Ray Players
Hello there, Something I cant understand, my
Your DVD player will accept only Divx disc ( AVI files ) So use an encoder to convert your files into AVI before you write them.
The standard DVD is a format called MPEG 2 and don't confuse it with MPEG4.
Download the program for free from the link given below for your conversion.
Apr 03, 2011 | H&B DX-3220 DVD Player
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
I have sound but no picture on the screen.. What did i do wrong
Hello sir, hi, please check the video cable. If you are using the three color audio/video cable, the yellow one goes to the yellow input of the TV to the yellow output of the DVD recorder. Then check the TVs audio video settings, the TV should be in the video channel, if there are several video channel, check where the video is coming in. Make sure that the yellow cable is good. you can swap several cables to check.
If your TV is component input, put the red green and blue wires to their respective color port, one end is on the DVD recorder, and the other on the TV. make sure your cables are good. Do the same thing with the S-video and HDMI cable. if your TV has this.
Nov 21, 2009 | Daewoo DVRS05 DVD Recorder/VCR
Sony BDP-S350 - no video..only audio on all outputs
This is button config for master reset without picture:
Home Left button x 3 Down button x 7 ok (centre button) ok Down button x 6 ok Left button x 1 ok ok wait a couple of seconds for settings to complete, when you switch back on you should have a picture and be back at language set up screen.
Hope this helps.
May 30, 2009 | Sony BDP-S350 Blu-Ray Player
Hooked up cables cant get video or audio
Make sure that your pluged into the proper inputs on the rear of the television. Double check them... (I've done this before too).
If you are sure the inputs are ok then make sure that your television is set to the proper input. Toggle the button on your television remote (input - source - device) for your input. Everyone is labled a bit differently.
This should bring up your dvd player when you reach the correct input.
Jan 23, 2009 | Samsung DVD-R130 DVD Recorder
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
Philips DVDR3380/05 DVD Recorder Logo
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
