Question about Sony KP-51WS500 51" Rear Projection Television
Unit will not turn on. standby indicator light flashing
  • rogertcrunk Jun 26, 2009
    This did not solve the problem. the unit is KP51ws520. It blinks 9 times
    My KP51WS520 will not turn on. Stanby light blinks 9 times
  • 152 Answers
9 blinks means, "Zero Crossing Detector"
This indicates a problem on the G-board and the part that most probably failed is D6301 with the part number 10ERB20-TB5.
follow the manual
(http://www.manual.agoraquest.com/viewtopic.php?topic=22865&forum=34 )
If you don't know what this means I'd reccomend contacting a certified electronics repair shop.
Posted on Jun 26, 2009
  • 3,267 Answers
I hope you have the remote with fully charged batteries. Also note the steps given for this issue:
The STANDBY light will flash if an issue is detectedwithin the television. This can sometimes be resolved by simplyfollowing the steps below to reset the television.
  1. Turn off the television. IMPORTANT: Fora projection television that uses an internal lamp, wait 5 minutesafter turning off the television to allow the lamp to cool beforecontinuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: Ifthe television is plugged into a power strip or surge protector, removeit from the power strip or surge protector and plug it directly intothe wall outlet. If the issue is resolved, the problem is with thepower strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center..........................................................................................sodeep
  • Sudeep Chatterjee
    Sudeep Chatterjee Jun 26, 2009
    As I had mentioned earlier you need to contact the nearest authorized service center and report the no. of beeps for them to help u out..........sodeep
I have a Denon AVR1603, recently I plugged computer in AUX connections at rear (not loud) and it kept tripping out. Eventually it tripped and now the the on/standby light fashes but nothing else happens....
The LED flash indicates that unit goes into protection. Check the power transistors, the 0.22 ohm or 0.47 resistors in the output of the transistors.
SAM ANDERSON
Sep 29, 2008 | Denon Audio Players & Recorders
Standby mode
When the STANDBY indicator
flashes
Immediately unplug the power cord
and check the following items.
• If your unit have a voltage selector,
is the voltage selector set to the
correct voltage?
Check the voltage for your region,
then make sure the voltage selector
is set correctly.
• Are the + and - speaker cords shortcircuited?
• Are you using the supplied
speakers?
• Is anything blocking the ventilation
holes on the rear of the unit?
After checking the above items and
fixing any problems, plug in the power
cord again and turn on the unit. If the
STANDBY indicator still flashes, or if
the cause of the problem cannot be
found even after checking all the
above items, consult your dealer.
Dec 20, 2012 | Sony Mhc-gn1300d 3 Dvd/vcd/cd Changer...
No pic or sound. the stand by light blinks green then the lamp light blinks red untill it turns off all toghther. the lamp is broken i just want to know if that is the only problem or if the driver may...
Flashing green standby led light at the front panel is an indication that the unit waiting for the lamp to turn on. Since the lamp led light flashes, the unit sensed it already burned out.
Faulty lamp driver has a different error code which is "flashing of the standby light 5 times".
Your unit will back to normal operation again after the lamp replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 22, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Televison & Video
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Sony Vega TV , On off switch
prolly u need the "D" board replaced--common to give error code of 5 to 6 flashes--unplug and wait to reset and try again
Jul 18, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony kv-30xbr910 my tv won't turn on and the standby fashes 7 times
Good day.
Your unit has issues with the high voltage section. Particularly the vertical and horizontal sections. Blinking lights indicates that your flyback is not osscilating to distribute the supply to the sections. Please have it checked by a repaiman.
chris
Mar 21, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Sony KP-51WS500 51" Rear Projection Television Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
