Question about Toshiba Satellite A215-S7422 Notebook
Toshiba satellite a65
Will not boot - removed battery - left in ac adaptor - get lights for a second then shuts down. got it to come up on screen with date and time but then it just sat and locked up
  • 1 more comment
  • jennifer488 Jun 26, 2009
    got to boot up loaded MSXP then went into a program and got exception. turned off - rebooted and it loaded windows again but then immediately went into this TRAP00000060 EXCEPTION screen with a bunch of codes
    yep - running really basic though because i have it for a race timing system specifically -
    I have the windows disks - but not any toshiba disks - bought it used. i rebooted again and got to the windows advanced options menu and it got frozen on this screen now. I do not have a system reboot disk - is that what i need?
  • Toshiba Master
  • 2,404 Answers
Uneseat and reseat memory once stick at a time in each slot one at a time. Turn on the computer after each stick reinsertion and see if you can get video. If you get video, try to go into the BIOS. If you can then its a matter of reinstalling windows. If you can't get into the BIOS and it locks, try a different known good working hard drive and if that works then go ahead and restore your system back to factory defaults.
If your gettting intermittent video no matter what you do then your motherboard is bad and would have to be replaced.
Posted on Jun 26, 2009
  • 1 more comment
  • Ben Wabnick
    Ben Wabnick Jun 26, 2009
    okay so at least we got video so we know the motherboard is probably good.
    You will have to reload your laptop back to factory defaults. Do you have the discs that came with the laptop originally?
  • Ben Wabnick
    Okay so you do have the original discs? Do you want me to help you get the system back up and running properly. Not sure how you would like fofr me to help you.
  • Ben Wabnick
    You'll need either a windows xp or vista cd depending on what you want to put on your laptop or you'll need the toshiba recover disks and there are you usually two of them. It would install the operating systsem and the other disk would install the drivers and utilities.
    Its can be restore either way. Since the laptop was bought used and its freezing up alot on you now, I would think that it has a bad hard drive in it. Best thing to do would be to get a known working good hard drive into the system and then do a restore with your windows disc and it should install the whole way. Give that a shot.
Wont boot past toshiba logo
Unplug the AC adaptor, remove the battery, then press and hold the power button down for a minimum of 30 seconds. Now replace the battery and see if it powers up. If not repreat the process but this time leave the battery out and only plug in the AC. If it still doesn't power on repeat the process again and this time replace the battery and plug the AC back in. If it still doesn't power up it's time to start checking the hardware. Remove the ram and try it with only one stick. You might need to try each one individually to see if either works. If that doesn't help remove the hard drive and see if it will post to the Toshiba screen. If that doesn't help you'll probably need to take it to a service center.
Nov 25, 2012 | Toshiba Satellite L775-s7352 Notebook...
Will not Power Up. I hit the Power button, green LED lights up for about 3 seconds (cooling fans start), but then shuts down. The battery is 3 months old, and the Power Supply is working.
Remove the battery and the power adapter. Now just plug in the power adapter and boot the laptop. Will it boot and remain on? If so then the battery is faulty. If not try a different power adapter, the worst case is that the system has failed. -Ravi Shanghavi
Aug 18, 2010 | Toshiba Satellite A65-S1762 Notebook
End of power cord has 20vdc. Whe it is plugged in the AC led does not light on the laptop. A65-S1066. How dead is it?
try checking the out put voltage from adaptor, if the adaptor has screws open it and check the fuse, remove batteries and check
Jul 08, 2009 | Toshiba Satellite A65-S1066 Notebook
Won't boot up past the Toshiba screen
Unplug any external devices. Remove additional memory if added. Take out battery and unplug ac adaptor. Press power button and hold for 20 seconds. Plug it back into the mains and try to turn on again. If this will not work replace mainboard.
May 26, 2009 | Toshiba Satellite Laptop with AMD Turion...
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Nov 29, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A60 powers up then off after 2 seconds
Mark F K, truong808, does the cooling fan(s) blow or come on? If not, the system will sense tha ti is overheating and will shut down to prevent further damage. Also, a thermal sensor may be failing on the Mobo and thus keep the fan from initiating. The cheapest fix is to replace the fan. Worst case scenario is another Mobo may be the fix.
Jan 06, 2008 | Toshiba Satellite A65-S126 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
114 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
