Question about Pool & Spa
JUST PURCHASED A LAARS LJ250 ELEC PROPANE HEATER. IWAS SURPRISED THAT A FIREMANS SWITCH IS NECESSARY, BUT NOT INCLUDED. CAN I RUN IT WITHOUT THE SWITCH AS LONG AS i HAVE THE PUMP RUNNING CONSTANTLY?
    President:
  • 1,378 Answers
A fireman's switch is not required, and usually not even "recommended". It is usually mentioned in the instructions only in the event you want to hook it up. The switch is actually a remote tied to a timer that turns the heater off ~20 minutes before the pump to save the gas and use up the remaining heat energy in the exchanger as the pump finishes it's cycle.
Posted on Jun 26, 2009
The screen on the heater says service AGS. The heater will not work.
check to see if pressure switch is working should have 24 volts ac on both sides make sure firemans switch is closed aqualink calling for heat and correct gas pressure
Sep 15, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars Lite 2 Heater will not go on
make sure little pump is moving if not check syphon tube going to pressure switch if ok check pressure switch
Jun 29, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Does the pool pump need to wired into the Jandy heater for the heater to work?
no if using a aqualink yes firemans switch to pins 1 and 2 on long green or gray plug if no aqualink the pressure switch will turn it off
Jun 15, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
I have a Teledyne Laars spa heater XE Electronic, ES 125 ; Question, The spa and heater was drained and cleaned about two years ago, I want to get running again, But before I fill the 500 gallon spa , Is...
Locate the pressure switch within the safety circuit and jump the two wires that are connected to it. Be sure the power is off when doing so. Then you can power up the unit and it should fire assuming all the remaining safety circuit switches are closed. DO NOT RUN this for more than a few moments as you can damage the heat exchanger rather quickly operating the burners without water flowing thru the heater.
John
Nov 09, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I get a service code of ext sw1
check safety circuit or firemans switch some controllers cut power to switch when off
Sep 05, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool Heater wont light
NO NO NO the heater is design to work on propane or natural gas only
Sep 10, 2009 | Jandy TELEDYNE LAARS GAS VALVE, PROPANE...
Solution for Jandy Lite 2 Pool Heater display flashes on & Off ..
Can a model LJ250P Propane 2005 model be installed indoors . The rating plate says it can. But manual says it cannot. What the hell????
Jun 06, 2009 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
96 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
