Question about Bosch SHU3306UC Built-in Dishwasher
Dishwasher stopped. no lights, no nothing
My Bosch 3307 always worked fine and one day -- nothing. The lights don't go on. Pushing the buttons does not activate anything. Is it a fried circuit board? If so, what needs to happen and how much $$$ will it cost?
My Kenmore just did the same thing, I verified power to the unit.
Posted on Jun 26, 2009
My Bosch SHU66C02UC dishwasher stopped midcycle with water in the bottom. We checked the fuse and it is fine. I'd rather not pay for a repairman as it is quite expensive.Thank you.
Some suggestions: try pushing the drain/cancel buttons and see if that drains the water; check the filter or trap in the bottom of the dishwasher for blockage; check the hose that links the dishwasher to the under-sink drain pipe for blockage. You could google the model number and find the owners manual, which might have trouble shooting suggestions.
Sep 05, 2017 | Bosch Dishwashers
I have a Bosch dishwasher SHX68T52UC/02 that has stopped working.
Hello!
Here you can find manuals to a huge range of Bosch dishwashers.
Hope you find a solution.
https://manualsbrain.com/en/brands/bosch/dishwashers
Aug 31, 2017 | Bosch Dishwashers
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
After turning the unit on (Bosch dishwasher SHE4AM0), it makes noises like it is starting, but after 1-2 minutes, the light switches from active to clean with no water ever being dispensed and no wash...
OMG The raindance works. I am not sure what worked, but here is what I did: 1) boiled water and put it in the dishwasher. 2) Started pushing buttons to try to do the "Setting Options" on page 13 of the useless Bosch manual. After a bunch of button pushing -- none of the things actually happened that the manual said would happen, but the thing started and is going through a cycle -- not immediately stopping. Wish us all luck in dealing with this poorly engineered product.
Jan 12, 2012 | Bosch Dishwashers
Wash cycle stopped with water in the bottom. Seems like there is no power. Can't get lights on cycles buttons to turn on. Power button does nothing. Checked circuit breakers. All are on. Lights and outlets...
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Jan 14, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My dishwasher just stop, the red light come on and nothing happen
check the filtrs in the machine are clear and the waste pipe is not blockedput it on rinse cycle and see if it empties
Jan 26, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Jun 13, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Bosch SHU3306UC Built-in Dishwasher Logo
227 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
