Question about Canon MultiPASS C555 InkJet Printer
Can"t receive faxes
I can't get my Canon mutliPASS c555 off of the answer mode. Please help.
  • 3 Answers
First of all, Canon has an excellent support site.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=8000
Secondly, it may be the way you set it up when you installed the printer. You have the choice to have the fax save the faxes to your PC or print them off. It's possible they're stored on your computer.
In any case, you can email or phone Canon support and they'll be glad to help.
Posted on Dec 26, 2007
Can't receive faxes
I suggest You Go to Official Canon Printer Page For You Canon Printer Problem On Below Canon forum URL Link: If You Cannot Receive Fax MF8350Cdn MF8050Cn In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Mar 04, 2014 | Canon PIXMA MX340 Wireless Office...
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I have a Canon MultiPass C555 InkJet Printer for my fax machine in the church office. I don't know how old the machine is. Whenever I receive a fax I cannot read it. I even change the ink and I still...
These machines have an integrated printhead built into the printer. The only way to try to fix this issue is to run the cleaning function anywhere from 3-7 times. First, remove the ink cartridges and depress the sponge side onto a paper towel. If you see ink on the towel, proceed to the next step. If no ink is present, replace the ink cartridges. They can be found for very cheap on this model. Next step, depends on whether or not the machine is hooked up to a computer or is just a stand alone fax machne. If it is not hooked up to a computer, go to the menu, scroll to maintainence and select clean cartridges. You will need to do this multiple times. Continue to do it if you see improvement, until you are satisfied with the print quality. You an also perform the cleaning from a computer. Locate the printer in the printer folder and right click on it. Select properties. At the bottom of that window, select preferences. Then select the maintainence tab, and select clean cartridges. Again, you will need to do this multiple times. Please advise if you need further help, or if this does not work and you would like info on current fax machines.
Sep 30, 2010 | Canon MultiPASS C555 InkJet Printer
I CANNOT GET OR SEND FAXES ANYMORE. IVE TRIED
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 25, 2010 | Canon MX310 Office All-In-One Printer
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Jan 08, 2009 | Canon FAX-JX200
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Jx300
What exactly happens when a fax should be coming through and it does not? Does the machine ring and fail to answer, or does it answer, possibly receive, and then not print? Which mode is the machine set for? Are there any error messages on the machine or other LCD message displayed?
Have you verified the telephone line is properly connected so that the machine is able to communicate? Make sure that the machine is able to use the telephone line by using the handset to make a phone call. If this fails, you will know to go through the phone troubleshooting problems, just as you would with any other phone issues.
If the phone line is functional, please reply with more detail re exactly what occurs when a fax should be coming through, e.g. does the fax machine answer the call or let it ring until answered manually? I believe that either there is an issue with the line, or there is an issue with the setup of the mode for receiving, but can not be more specific without more information.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jul 23, 2008 | Canon FAX-JX200
Can not receive fax
Make sure the fax is set to receive automatically. The receive mode must be set to one of the following modes: Fax Only, Fax/Tel Auto Sw, or Ans Machine. If it is set for Answering Machine, be sure the machine is connected to the fax, turned on, and contains a recorded outgoing message.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 24, 2008 | Canon FAX-JX200
How to set ringtone when receiving fax Canon Fax L800
RINGER IS SET TO SILENT MODE,PLEASE CHANGE IT HAPPY FAXING OMNIPRESENT
Sep 19, 2007 | Canon FAX-L800 Plain Paper Laser
Canon MultiPASS C555 InkJet Printer Logo
51 people viewed this question
old marine
old marine
