Question about Samsung SCH-u410 Cellular Phone
Outside screen does not light up when call comes in and inside screen white. i notice some condensation under the outside screen.
  • 389 Answers
There might be a moisture damage on the phone. the reason why it is malfunctioning
Posted on Jul 03, 2009
Whirlpool duet dryer
When the dryer is not is use, it is recommended to leave the dryer door open. What you are experiencing is probably due to outside air coming back thru the dryer vent (the louvers don't always close well due to lint). The temperature difference between the outside air that accumulates in the dryer and the inside air causes condensation.
Aug 05, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Compresor wont start and when it does it cycles on and off
Does the condenser fan come on? I am assuming the evaporator fan (inside) is blowing? The way these units are wired is that the power goes the the inside unit and the controller inside sends power to the compressor and condenser fan. But if the controller detects that the condenser fan is not turning (via no ground return) it will not send power to the compressor. This to protect the compressor. Did you notice it trip a breaker? When it is on, do you have 240 on the unit outside but not 120 to ground from each leg?
Jun 15, 2010 | Sanyo CMH2472 Air Conditioner
Inside temperature of freezer is getting warmer
hi the first things you need to check are ... is the condenser coils or fins are dirty the condenser coils are usually black and are under or on the back of the freezer also check if the unit has a fan motor and blade ON THE OUTSIDE make shore its turning ... you can vacuum the condenser coils or, use a brush , or compressed air, to clean the condenser coils hope this helps if not let me know jason
Jun 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
Unit not coming on. air isn't getting cold
First check the breakers for the condensing unit (outside unit) and the disconect outside by the unit (could be a breaker ,a pull off/on switch or fuses)If its ok , you should have 220 ,240 volts to the unit contactor (you'll see it after removing the cover on the condensing unit).When the termostat is in the cold position and the temperature its set is lower than the one inside the house the contactor should be pulled in and give power to the compresor and the fan.But if the termostat is in the cooldest set and the blower inside the house works and the contactor in the condensing unit is not pull in the problem is in the termostat or in the low voltage wire.
Apr 24, 2009 | Heating & Cooling
Outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Jul 25, 2008 | LG LRFC25750 Refrigerator French Door
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Samsung SCH-u410 Cellular Phone Logo
46 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
