Question about Philips Magnavox DVD+R/+RW Recorder/VCR
What does DVD recording error E6 mean?
Magnavox Digital Video Disc Recorder & Video Cassette Recorder model ZV427MG9 A.
What does DVD recording error E6 mean? Manual page N33 shows some of the error message meanings but E6 is not detailed. All it says is Error numbers E1-22 and E37-39 means "Recording error other than below". That's no help at all. Any ideas what error E6 means?
Thanks, Kitty
  • 814 Answers
SOURCE: Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
Posted on Jun 02, 2009
SOURCE: I have a Magnavox ZV427MG9 A VHS & DVD Recorder
Ensure that your source is correct. L1 is the rear inputs and L2 is the front inputs. If you have it set to L2 then you have no information from the TV getting to the recorder.
Posted on Sep 23, 2009
SOURCE: this program is not recordable in +vr mode
This means exactly that these are copy Once only, meaning you can not make it copy say 10 copies, at the same time, it means you must do one a at a time. If you wanted say 10 copies, you must do the entire process over and over.
Posted on Apr 02, 2010
Testimonial: "THANK YOU SO MUCH, THIS LEADS ME IN THE RIGHT DIRECTION, I GUESS I NEED TO CHECK THE SETTINGS ON MY PLAYER"
SOURCE: I have a SV2000 Vhs/Dvd Recorder. I can't seem to
Do I have to download something to be able to record vhs to dvd on my sv2000 dvd/vhs recorder?
Posted on Sep 12, 2010
SOURCE: ZV427MG9 A It will not record when recording from
same as above,check the mode swith.i's stuck in the dvd posision,you need it in the vcr mode to do that proceedure.
Posted on Oct 29, 2011
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
My Magnavox Digital Disc Recorder & Video Cassette Recorder will not play DVD-RW discs. How can I solve this problem or get a replacement unit.
It claims to play -RWs finalized in DVD-VIDEO format, not VR. If a disc is recorded/finalized on a different recorder, not all players can play it. This is the price we pay for the convenience of the digital system.
Feb 11, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
    U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
    Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
    I just bought the zv427mg9 a and I can not get it to pause recording when recording from vhs to dvd. Can you help?
    the magnavox ZV427MG9 vhs to disc dub recording can not
    be paused. you can not pause and start dub recording in this
    mode. you must let it run start to finish . It also states this
    in the manual which disspointing....
    For this type of recorder it should be able
    to do just that, pause while dub recording whs to disc, but it
    doesn't.....
    Aug 22, 2010 | Philips Magnavox DVD+R/+RW Recorder/VCR
    How do I connect the Magnavox to my cable?
    If you are talking about the Magnavox ZV427MG9, this unit is a Digital Video Disc Recorder and Cassette Recorder. There are no connections for the RF cable (analog) that is normally connected to the back of the TV from the cable company or satellite receiver. However, you can use RCA connectors, S-Cable and other cables to connect to your TV if your TV has these types of IN and OUT connections available. Most TVs made in the past 5-7 years have these types of connections.
    Aug 14, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
    Televison & Video Logo
    1,184 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
