Question about Garden
Gas does not go through the primer bulb, so no gas to primer and get started. Pumping Bulb puts air pressure in the gas tank. Gas appears to be flowing to the carb in the other lines. Bulb will not fill with gas.
  • 376 Answers
Unless you had the fuel lines off or replaced them, leave them where they are. The problem most likely is in your carb. The diaphragms are possibly brittle or the needle is stuck from varnish from old gas. The easiest solution is to replace the carb.
Posted on Jun 27, 2009
  • Joe V Nov 21, 2011
    ok I have the same probelm. but I had broken fuel lines. I replaced them and put a new primer bulb on and the bulb won't fill..... the only thing i can think of is air leaking around the holes in the tank when the primer bulb is pressed.. how do you fix that?
  • 59 Answers
Change the gas lines around
Problems getting gas from gas tank to my outboard 15 HP 4 stroke Mercury.
need to clarify your statements
you say-- have replaced flexible lines from the tank to the engine --replaced the primer bulb
well that is all the rubber hoses from the tank to the pump on the engine
Then you further state only parts not replaced are the connections between the
gas tank and the motor and the tank itself
Well that connection is the rubber hoses that you stated were already replaced
So this may help rubber in outboard motors rots internally so replace all rubber from the tank to the motor, overhaul the fuel pump on the motor and all the rubber hoses from the pump to the carby/s
the primer bulb will not pump fuel if the tank vent is not open so that is one reason you feel like it is pumping air when priming
best advice is --no e-mix fuels to used on out board engines
Sep 18, 2017 | HP Garden
Primer bulb not pumping fuel,new bulb !
are you sure you put it on the proper direction . they only work one way normally
Feb 16, 2017 | Garden
How do I replace gas line on Ryobi Grass Trimmer 34005?
One is the return line from the carb, the other goes to the primer bulb.
Jun 26, 2016 | Garden
Stihl chainsaw primer bulb will not fill. Puts pressure in fuel tank
try switching the tubes on the back of the primer bulb
Nov 12, 2013 | Stihl Garden
Carburetor change
Primer bulbs pull fuel from the carb, into the bulb and dumps it back to the tank, if you have re connected the hoses to the primer the wrong way around it will try to force fuel into the carb and make it flood.
Jun 01, 2013 | Poulan Garden
Craftsman weedwacker 358.791070 stopped running; found broken fuel line in tank; changed same;when pumping primer bulb,the line between tank and carb fills up but line between bulb and into return line to...
the filter on the end of the line in the tank may be clogged or the gas cap may be bad they are designed to hold pressure and help push fuel in to the carb
Feb 28, 2012 | Craftsman Garden
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
Fuel dont get in carbruator put gas in the carb thru the choke it starts but dies .i put a new gasline in it and a new carb kit Why dose pressure build in the fuel tank i removed the fuel line and gas...
When you prime/puge your carburetor, make sure fuel (w/ no air) is moving from the fuel tank towards the body of the carb. Also, make sure that there is fuel/air bubbles leaving the primer bulb and going back towards the fuel tank...and that when you push the bulb down and release it, there is no fuel movement in either line. If fuel does move when letting up on the bulb, you either have the fuel lines reversed or, the check valves in the primer base assembly are not functioning. The primer/puge valve's funcion is to draw fresh fuel into the fuel pump side of the carb and to push old fuel/air from the metering chamber side of the carb back to the fuel tank. Here is proper fuel routing:
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Sep 03, 2010 | Homelite Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
1,117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
