Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When i turn on my sony bravia kdl-40w5500 there is just a blank screen and after about 10 seconds it will go onto standby and the standby light flashes 14 times and then pauses and flashes 14 times again. this will continue until i switch the power off at the mains.
5 Suggested Answers
SOURCE:
  • 148 Answers
SOURCE: My Sony KDL-40W5500 TV won't switch on: standby
NOOOOOO, do not buy a new one. Your problem , if you fixed it my way yourself, would only cost you around$3.00 to $5.00....
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped you (or not) , then please rate!
Thank you.
Posted on Feb 02, 2010
  • 8457 Answers
SOURCE: Sony Bravia KDL-46Z4100 - tv turns off after being
Ur tv power supply board have dead parts call capacitors.U know basic electronic's and soldering?Take ur tv aparts,check the power supply board,that the board the power cord plug into it.Searches all around for these dead gas leakage capacitors,they all way bulges up on it top,or puff up on it top.Replaced these dead gas leakage capacitors,ur tv will have stable LED light and the power will work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on May 24, 2010
alpug
  • 1961 Answers
SOURCE: I have a Sony Bravia
probably there is a problem on the power supply section of your tv the cause of it is a deffective bulging capacitors.replace all the bulging capacitors from the power supply.
Posted on Oct 16, 2010
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia 46" The standby light flashes four
If tv model number is KDL-46S2000 then 4 times blinking standby light indicates back light failure problem in your tv.
Check/ replace back light inverter boards to solve its problem.
Thanks.
Posted on Dec 29, 2010
NEED A USER MANUAL FOR A SONY BRAVIA TV MODEL KDL-40W5500 MODEL 9201533AN YOU HELP PLEASE THANK YOU
Sony has the manual for the KDL-40W5500 on the product support page: http://www.sony.co.uk/support/en/product/KDL-40W5500 . Scroll down to the Manuals section and there are two documents immediately shown. There are additional manuals stored on various Sony sites available, if you click on the link for all manuals. The direct link for one version of the manual in English is http://download.sony-europe.com/pub/manuals/swt/Z006/Z006062111.pdf .
I hope this helps.
Sep 11, 2016 | Sony BRAVIA KDL-40W5500 FULL HD...
Sony kdl 40w5500 hdmi not working
Take it to the technician he can only solve the problem.
Jul 01, 2013 | Sony BRAVIA KDL-40W5500 FULL HD...
Sony bravia turns on and off by itself then stand by light blinks 10 times
Google the model number of the set(not indicated here) for "error codes" or 10 blinks---Also look on the Sony site for this information--you can call them with the model number also.
Apr 16, 2012 | Televison & Video
Thanks.
Dec 29, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a Sony Bravia KDL-40W5500 LCD TV (11months old) that does not show a picture when turning on from standby. Sometimes it only gives sound for a shot while then automatically reverts to standby. the...
Oct 16, 2010 | Sony Televison & Video
Buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
261 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
