Question about Frigidaire PLMB209DC Microwave Oven
I have an Amana AMV5206AAS over the stove microwave oven. It was manufactured in May 2004. About a month ago it began making a loud, metalic, grinding or dragging sound after 1-2 minutes of operation. It continues to heat and does not make the sound if it is run for less than a minute. Given the age of the machine, is this a problem that warrants a service call or is it a lost cause? The warranty will cover the magnetron up to 5 years, so I might have to cover the cost myself. Is it worth fixing or should I get a new microwave.
  • William Miller
    William Miller May 11, 2010
    I would first check the stirrer blades for arcing due to grease deposits or mechanical binding. You would need to remove the stirrer cover. It's in the ceiling of the oven and held in place with a rivet. You can find
    helpful exploded view diagrams and order parts by entering your full
    model number from the tag on the oven here. You can also temporarily leave the cover off long enough to test the oven. Heat some water about 3-4 minutes with the cover out and see if you see any arcing or see the stirrer hitting or hesitating. If the sound is like gurgling into a coffee cup, that is a bad magnetron. Can you post a sound clip or video with sound?
5 Suggested Answers
  • 1922 Answers
SOURCE: how do i check the fuse of amana microwave model
Posted on Sep 26, 2009
  • 9098 Answers
SOURCE: My Microwave oven makes a loud buzzing noise and
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually on the right side of the cavity and is about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Your owner's manual may show you how to remove the cover.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Otherwise, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 31, 2010
  • 130 Answers
SOURCE: Less than 5 years old
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Posted on Dec 02, 2010
Testimonial: "Quick and accurate! Will go ahead and replace the entire unit. Thanks REPAIRMAN45!"
  • 670 Answers
SOURCE: My Frigidaire microwave is less than a year old.
The symptoms of loud noise and no heat indicate a short in the magnetron or high voltage diode. Need to take it to a qualified repair, to figure out what the problem. The magnetron replacement can cost as much as a new oven. See what the warranty covers, maybe you might luck out.
Posted on Dec 07, 2010
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
My microwave over does not shut off
I'm sorry, I don't have an answer, but my radarange also began this odd behavior about a month ago... my son is a mechanic has almost forbade me to use it, stating he gets a headache everytime he opens it.... Once the range stops cooking, I open the microwave to get the food out, and the range immediately turns back on, lights on, and carousel turning! I have NO IDEA if the microwaves are engaged at this point???!!! But suppose I need to find out ASAP!
Oct 10, 2014 | Amana Radarange Microwave Oven
ASD2624HEQ part break down
most are very similar, hope this works.
Feb 18, 2012 | Amana AMV5206AAS Microwave Oven
Our microwave is making sounds like an electric can opener all the works like normal.
HI.Though this suggestion may be recommended by those .but just to make sure how does the motor moves or rotates.If you can open both side of the oven if the motor boosing has been busted. Motor is reponsible of rotating the turntable,it has boosing on it try to check if it is already losse.And try to check also if there are debris that clogged in as the motor rotates.any metal that clogged inside the ovcen.hope this suggestion helps.Thank you for choosing FIXYA.
Jul 18, 2011 | Amana AMV5206AAS Microwave Oven
Are microwave safe egg poachers doing damage to microwave?
you are not supposed to have any metal in the microwaves for cooking something , as why the other two quit , that is probably why they quit so soon
there is some more exspensive microwaves that can work even when metal is used inside( but these are special types of microwves)
Nov 10, 2008 | Danby DMW1153 Microwave Oven
Mwave made loud buzzing noise then didn't heat up anymore
When there's a loud buzz like that, it does not heat, and does not blow the fuse, it is usually a defective magnetron. Did it sound something like someone making a "gurgling" sound into a coffee cup? I think this has a a one-year warranty, with n five-year warranty covering the magnetron. You can find a local Amana-authorized servicer here:
Mar 03, 2007 | Amana AMV1162 Microwave Oven
Frigidaire PLMB209DC Microwave Oven Logo
52 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
