Question about KitchenAid Cooktops
One burner igniter fails to spark after getting wet
My customer's sealed gas burners got wet.
Now one (of 4) won't light -- no spark from the electric igniter. Can this be fixed?
Gas flow is just fine and burner lights manually no problem.
Thanks! ~Jim
Each burner has its own switch to direct current to the igniter. It appears that one of the four switches burned or shorted out, while the other three survived the flood. These switches are replaceable, so that's how I'll fix the problem.
Posted on Jun 27, 2009
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
All 4 electrodes spark when only one is turned on
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
How do we get the electric igniter to go off?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 02, 2010 | Whirlpool GLT3034 Gas Cooktop
I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
Aug 18, 2009 | Jenn-Air Cooktops
Two of five cooktop burners fail to light
you can try to scratch the area where it grounds to with a wire brush or screw driver this will help sometimes. sometimes when it archs down try tighten the screws to lift up the ignitors into the hole better. or if this doesn't work replace the ignitors.
Jun 07, 2009 | Jenn-Air JGC8536 Gas Cooktop
Spark igniters on the burners fire continuously
When cleaning, if the control switches get damp, they will react as you describe.
Unplug the appliance, use a hair dryer and attempt to dry the switches.
Leave it unplugged overnight and try them again tomorrow.
They will eventually dry and be OK.
Feb 24, 2009 | KitchenAid 31 in. KGCC505 Gas Cooktop
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
Clicking on one of the burners
sound like the spark switch got wet or has failed, if it has gotten wet from cleaned to stop the clicking unplug the ct of 24 to 48 hrs to allow time to dry out if that does not work call a appliance service company
Jun 03, 2008 | Jenn-Air 35 in. JGC9536 Gas Cooktop
It is not a GE but it is a Jenn-air
It's either a bad spark module or switch.
Nov 17, 2007 | GE 36 in. JGP628 Gas Cooktop
Cooktops Logo
511 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
