Question about Sewing Machines
Brother se-350 thread is balling up, shredding, etc.
  • 4 more comments
  • jkmohio Jun 26, 2009
    that's just about the only thing I haven't tried yet! Also, I was wondering what setting the top tension should be on. If I put it higher than 1, the thread won't pull through. Is this normal? That's with any fabric. Now I'm trying to embroidery handkerchiefs and I"m having the balling/threading issues. Thanks for your help, I look forward to hearing back!
    I have to loosen it for the thin materials?
    Ok, I'm trying that now. I'm noticing as my upper thread feeds, it gets very loose and I thought that was the problem orginially, so I started adjusting the upper tension, etc. I just loosened the lower, I'm going to see what the machine does.
    you said the tension, on top, should be on 1. Is that for all embroidering or just for this thin fabric? So far, it hasn't jammed.
    Ok, so it hasn't jammed, at this point, but now I can see the white bobbin thread (I'm using blue on top) coming up through into some of the letters. Is this the same tension issue?
    Thanks so much! I can now finish embroidering those Father's Day handkerchiefs!! You were so helpful!
  • 15,935 Answers
Your thread tension needs adjustment.
Most likely it is the lower thread tension (not the upper thread tensioner).
When sewing very thin or very heavy material - it is required to adjust the lower tension as well.
To regulate the lower thread tension - turn the small screw on the tension spring of the bobbin case with a small screwdriver.
To increase tension - turn it clockwise SLIGHTLY.
Thanks for using FixYa!!
Posted on Jun 26, 2009
  • 2 more comments
  • blueextc3221
    blueextc3221 Jun 26, 2009
    that should be on 1, and the lower tension should also be LOOSENED by turning counterclockwise.
  • blueextc3221
    OK
    Thanks for the update
  • blueextc3221
    The tension is adjusted based on the thickness of the material. Less tension for lighter material... and a test should always be conducted before trying the final product so the tension is adjusted properly.
    Have Fun!!
  • blueextc3221
    yes - it will require constant test adjustment until you get it how you want it. It will get easier with more use and practice.
    Dont give up!!
How to replace spool pin on brother se 350 sewing machine
Is this a chromed metal shaft that stick straight up?
IF SO, the broken piece can be PROBABLY be unscrewed using pliers. Then you have the thread size, the piece, that you can take to a hardware store and get a long blot this the same threads.
The part can probably be found on the internet using google.com or on eBay.
92results for Brother sew spool pin
Mar 18, 2015 | Brother SE350 Mechanical Sewing Machine
How do I adjust the tension on brother SE-350?
Before you go adjusting tensions, make sure your upper thread is threaded properly. Always thread with the presser foot in the UP position so the thread can slip easily between the tension discs. Also make sure there are no wraps around the thread spool spindle.
Be certain that you have the bobbin properly inserted as well.
Once you are absolutely certain that there is no issues is threading. The tension is adjusted by a wheel on the top of the machine. Left to loosen, right to tighten the tension.
Jul 04, 2014 | Brother SE350 Mechanical Sewing Machine
Brother SE-350 "The safety device has been activated"
Return the bobbin winding shaft on the top right of the machine to the Left Position. It may be stuck in the middle.
I had this same problem. After an hour or two of fiddling, this fixed my problem.
Dec 22, 2009 | Brother Sewing Machines
Stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Dec 10, 2009 | Brother SE-270D Computerized Sewing...
Sewing machine skipping stitches and shredding thread
http://www.allbrands.com/products/15289-brother-pq1500sl-9-arm-straight-stitch-sewing-quil
Oct 03, 2017 | Brother Sewing Machines
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
Bobbin on SE 350
Hi there, this seems to be a common problem with this machine. I have owned mine for a couple months now. The problem seems to be in the threading. The only solution I have found (and others on many forums) is to rethread the machine and the bobbin. I have also re-wound some problematic bobbins as they just maybe did not wind tight enough. Don't delete your patterns, that is not the problem. I have had proffesional patterns turn out a dozen times and then give me problems only to be fine once the machine decided it was threaded properly.
Feb 14, 2009 | Brother XL-3500
Tangled thread under metal plate
-The bobbin is too lose. Tight the adjustment screw on the bobbin case a little more and test, keep doing until it's good.
-Or possibly the upper threat is too lose so it won't pulls the bottom up as well.
-Check it out and adjust it.
Good luck
Mai
Jan 18, 2018 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
70 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
