Question about Siemens 24 in. SE25A266 ExtraKlasse Free-standing Dishwasher
Where does the salt go?
Dumb question, but I'm not sure where to refill the dishwasher salt (the 'Salt' light in the front of the machine is red, so I guess I do need to do this). I live in a rented flat and I don't have the instruction manual. There are two places inside the machine where it could go: one is a little flap that seems to have an 'S' on it, but this is full of water. The other is a sort of mesh grille, but that too has water inside when you removed the mesh. I'm a bit stuck - hopefully someone can help!
I think my model is a SF24A261GB/08 slimline, but there doesn't seem to be a specific page for this.
  • 641 Answers
SOURCE: dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Posted on Aug 18, 2007
murdozzz2
  • 75 Answers
SOURCE: salt refill
hi there salt is only req,d if you live in a hard water area ie. if the element on your kettle gets all furred up, using salt in your d/w in a soft water area is a total waste of money.
hope this is of some help
Posted on Dec 12, 2007
  • 1462 Answers
SOURCE: salt for DDW1805 Danby
yes it is - salt is used to regenerate the water softener in the dishwasher
Posted on Jul 12, 2008
  • 5 Answers
SOURCE: Salt tray full of water
No problem - just tip it in and it will displace the water.
Posted on Oct 07, 2008
  • 12 Answers
SOURCE: Salt lasts only a very short time in dishwasher
is there any funny noises while using the machine that are new? if there is it may conclude that there is a leak in the machine and needs urgent assistance that may flood so act now! good luck!
Posted on Sep 30, 2009
Do you need to put salt in the dishwasher. If using tablets detergent ...where to put it ?
A lot of dishwashers do not have salt dispensers. If it does, the salt is added to a container which has a lid on the base (floor) on the inside under the bottom basket. Unscrew the lid and add the salt. Use normal pool salt. It is the same as "special dishwasher salt" that you pay a lot for. When full, the salt will last for 12 to 18 months. Most machines that have a salt container, also have a warning light on the panel to let you know it needs refilling. Dishwasher tablets do not add salt to the machine. Make sure you wipe up any salt that you may have spilt on the base of the machine, it will stain or rust the cabinet.
Sep 25, 2014 | Dishwashers
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
Hi, my wife refilled the salt, then the machine starts but won`t fill or cycle through. We`ve removed any excess salt; still nothing. Any ideas?
The watter inlet is cloght with salt,flip the machine side ways and shake it a bit the salt cristals should move from the water inlet
Oct 19, 2013 | Electrolux 23 in. ESL6114 Built-in...
Aquarius DWF32 and dealing with water softner
Good idea to check levels yourself, but wear rubber gloves as dishwasher salt will leave your hands very sore, simply remove cover from salt tank, using a wooden spoon handle or similar check salt level and refill if required, replace tank lid, never wait for warning lights, they may never come on, good luck.
Feb 18, 2013 | Hotpoint Aquarius Washing Machine Front...
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
White film on glasses. Cannot find solution,
Check water quality. clean the drain filter in the machine. Check spray arm spray jet holes. Clean if clogged.
If you suspect salt chamber try removing all the salt by flushing with water externally. Refill with fresh salt.
Jul 08, 2010 | Servis 23 in. M4306 Free-standing...
Red light continues to blinkafter wash cycle is
try adding salt to the resovior in the bottom of your dishwasher.. machine will not run without salt so as not to cause damage
Dec 14, 2009 | Kenmore Dishwashers
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Jan 05, 2008 | Miele 24 in. Novotronic G641 Plus Built-In...
Siemens 24 in. SE25A266 ExtraKlasse Free-standing Dishwasher Logo
614 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
