Question about Sony KDF-50E2000 50" HDTV
How long do I have after the lamp replacement warning comes up before I have to replace the lamp?
  • 668 Answers
That is a unknown. It could be day or two or a month depending on how much use it gets. If the lamp was replaced befor and the internal Lamp Counter was not reset in the Factory Mode, it could be a false warning.
Posted on Jun 26, 2009
2012 cbr 1000 check engine light 2 slow 3 fsst
warning lamp some used for warn low oil pressure, etc.
Wtith the bulbs use for most warning light circuit it is hard to determine whether or not the filamente is good. Will be a good idea to replace the bulb.
For test the faulty warning lamp, turn the ignition switch to START, this light the warning lamp. I f the light does not come on , disconnect the sender switch lead. . Use a jumper wier to connect the sender witch lead to ground. With the ignition in RUN the warning lamp should light. If the lamp is illuminated replace the sending switch. If the light does not come on,either the bulb is burned our or the wiring is damaged.Use test light for confirm voltage is present at the sensor terminal connector. If there the bulb is bad.
God bless you
Oct 05, 2012 | Cars & Trucks
97 lincoln mark viii oil pressure light always on. oil pressure good. new sender
test the faulty lamp , turn on the ignition switch to the START position The providing circuit shoudl ligh the warning lamp. If hte light does not come ON during the porve/out, disconnect the sender switch lead. Use a jumper wire to connect the sender switch lead to ground . With the ignition in the RUN position, the warning lamp shoud light. If the lamp is iluminated, replace the sending swith. If the light does not come on, either the bubl is buned out or the wiring is damaged.
God bless you
Sep 28, 2012 | Cars & Trucks
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
My toyota hiace is 1986 model 2,4 and diesel.the problem is the battery lamp warn and the battery dicharge all the time , and the generator is together whith oilpump and where can i find the generator...
If your charge warning lamp is coming on then you have a problem with the alternator. You need to replace it with a reconditioned item or new item. The charge lamp relay is operating ok because the charge warning lamp is coming on.
Have this done and your battery will stop going flat.
Thanks
Jason
Jun 10, 2011 | Toyota Pickup Cars & Trucks
If I reset the timer before replacing the lamp,will the please REPLACE LAMP warning stop appearing???
Replace Lamp first, then is reset timer come up Go to menu lamp Timer reset.Most of the time TV resets itself after installing New Lamp.
Sep 21, 2009 | Sharp Televison & Video
How do you reset the warning to replace lamp.i replace the lamp on my pt-50dl54 but the replace lamp still comes on
Turn your television on
Press volume down on the TV
Press the mute button on the remote
Green LED light on power button will flash
-timer now reset (no more warning light)
Nov 15, 2008 | Televison & Video
Optoma H77 - Lamp shuts off after coming on for 5-10 minutes
Hi SoonerJDP
This is indeed a warning that the hours on the lamp has been used up and that you will have to replace the lamp.
Remember to reset the lamp timer once you've replaced the lamp.
May 18, 2008 | Optoma LFU250E Projector Lamp for H77,H79
Intermittant lamp cycling
could be lamp or lamp driver the only way to tell is to replac on at a time.
Aug 11, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
Sony KDF-50E2000 50" HDTV Logo
273 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
