So to clarify, the T.V. turns on but the system doesn't turn on with it? Most external sound systems have their own and separate power supply. You will need to turn it on as well as the T.V.,
Click Start, right-click My Computer, and then click Properties.
In the System Properties dialog box, click the System Restore tab.
Click to select the Turn off System Restore check
box. Or, click to select the Turn off System Restore on all drives check box.
Click OK.
When you receive the following message, click Yes to confirm that you want to turn off System
Restore:
You have chosen to turn off System
Restore. If you continue, all existing restore points will be deleted,
and you will not be able to track or undo changes to your computer.
Do you want to turn off System Restore?After a few moments, the System Properties dialog box closes.
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
It seems that your ps3 is experiencing the yellow light of doom:
Try this:
1. Turn off Playstation®3. 2. Hold the power button down; the system will turn on and turn off once again. 3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps 4. When you hear the 2 beeps take finger off power button. 5. You will be prompted to plug in your controller via USB and then hit the PS button 6. The Recovery menu will pop up.
The current Recovery Menu supports: • Restart System: Restarts the PLAYSTATION®3 System. • Restore Default Settings: Reset all system settings back to default. • Restore File System: Checks for corrupt/missing system files. • Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. • Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch. • System Update: Update the PLAYSTATION®3 System
Try to download and install AVAST antivirus Home Edition. It is free. Besides, avast has an option to scan at boot time so it can detect and delete viruses and malwares before they can cling to your system memory. You can download it here.
to get to the system restore for sure ..get to the control panel ... be sure it is switched on category view...and than click the maintenance and performance...in this moment in the left side task bar you will have the initiation of the system restore......BUT! if the system was turned off until now..you will not have any previous point to get back to ..so ..what you have to do is turn in on and you will have a point from now on...and a point will be made each time you install or uninstall anything .. you can also turn the system on ...by right click on my computer icon...choose system restore...and uncheck the case that says turn off he system restore..I actually believe it will be possible to turn it on from both ways.. Have a nice day ..and dont forget to rate ...!
change the function to cd or aux before you turn it off and then change the volume before going to your preferred function. It is the only way around it.
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
