Question about Toshiba Satellite A215-S4747 Notebook
My computer screeen will back out sometimes while the computer is still on. Sometimes, if I turn my computer on and off again it will work normally but sometimes it wont work at all. What should I do
  • Toshiba Master
  • 32,281 Answers
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 26, 2009
Why wont my tablet lock and the volume keys won't work?
in settings, try to put the "sleep" timer to 2 minutes, and see if it actually locks (or sleeps:turn off the screen)... also with mine sometimes the "capture screeen" feature works (more donts than do's!) perhaps very poor quality from the buttons.
clean all the apps running, and start with a full fresh boot (turn off by holding the power button 10 secs or more, then conecting to the charging usb, press again the power button), the volume also can be set via software, again in settings.
Aug 24, 2014 | Insignia - Flex 10.1" Tablet with 16GB...
High idle
What control idle is RPM sensor[TPS] to check it is OK.
Jan 28, 2013 | 1999 Pontiac Grand Prix
Sometimes when I turn the key to start the car, it makes a little buzzing noise, and sometimes it starts and then again it doesn't. Other times when I turn the key, there is nothing. Turn the key back...
Hi and welcome to FixYa!
As a first course of action I strongly suggest that you disconnect the positive battery connector and let it sit for at least 5mins. then reconnect it again. This will reset the car's computer and can get it back to it's normal operation.
Sometimes the car's computer trips and needs to be resetted by removing the positive battery connector. If the problem still persists, I strongly suggest that you have the car scanned to know the fault and by then you will know the fix.
Hope this helps and thank you for using FixYa! have a good one!
Feb 13, 2011 | 2004 Honda CR-V
My computer goes to sleep and sometimes I can't wake it up.
When is asleep try to close the lid completely and open it again. This works for mine sometimes.
Jul 23, 2010 | Dell Inspiron 530 Desktop Computer...
HP dv9000 screen shutdown
Power controller circuit on the motherboard needs repair by pro.
Oct 08, 2009 | HP Pavilion dv9000z Notebook
Monitor displays black screen
when you power up the computer pres F8 key thene enter in safe mode.then uninstall vga graphic driver then reinstall it in normal mode.
Aslo check your screeen resolution settings it should be 1024*768
Jul 22, 2009 | Acer Aspire 5315 Notebook
I have a siemens speedstream 4200 modem. It gets very hot to the touch, is it good to turn the modem switch off sometimes when you have your computer shut down?
Sometimes it's normal for some modems to be very hot. Make sure it's no in a very enclose space. And yes it's ok tp turn the modem switch off sometimes if you have to shutdown the computer. Just be sure to turn on the modem first then the computer in that sequence when you need to use them again.
May 08, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Noritz not staying hot
How many faucets do you have on when this happens? Turn on more than 1 and if it still does the samt thing than I would check to see if the inlet water screen has debris in it. Valve off the unit and look at the inlet water side and theres a screeen that you should be able to remove and clean undeneith some running water and then replace. Good Luck
Jan 07, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Nextbase SDV1102-B has black screeen.
I have also one liket that and had the same problem.
The connector is moving and the screen changing from black to white but sometimes nothing. I've managed to have the screen back normal but only for a moment.
Now it is dead again.
I'm sure it is he connector to the screen which is very sensitive.
Dec 12, 2008 | NextBase SDV-17 Portable DVD Player
Toshiba Satellite A215-S4747 Notebook Logo
126 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
