Question about Samsung HCM4215W 42" Rear Projection Television
Tv wont turn on
Tv will not turn on. timer light up front flashes, can hear relays clicking??
Re: tv wont turn on
Further, I've replaced the convergence board, but that didn't fix it either.
Posted on Nov 08, 2007
0 characters
3 Points
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Tv wont turn on
Green light of death, capacitors have to be replaced but it probably wont fix it anyways. Once this happens the TV is completely useless.
Jul 21, 2010 | Mitsubishi WS-65809 65" Rear Projection...
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
Turning on green light starts flashing only to hear a click and then the red light starts flashing... tv will not come on.. i can hear a fan that seems to start up...
The power up sequence is being interrupted and this could either be the main power supply or a protective shutdown of the supply because of a downstream failure. The clicking you hear is the activation and dropout of a relay.
If the flashing seems to be in a pattern, it may be telling you what has failed via the coded flashing. Any Sony service (or service tech) can tell you what the problem likely is if there is a pattern to it.
Nov 29, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Flashing green timer light,blank screen,consistent clicking noise
The Chassis will need to be sent to Mitsubishi to be refurbished. The Boards are not available and have not been for quite some time. Due to the cost of repairs, I recommend you to call Mitsubishi at 1800-332-2119 to see if they could help you with the cost of repairs and also to refer a Service Facility local to you to do the work. I would estimate the cost of about 300.00 to 400.00 if Mitsubishi helps with the repairs. If they don't. I estimate 700.00 to 800.00.
I hope this helps,
Sky Assoc
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Projection Televisions
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
77 people viewed this question
Top Samsung Projection Televisions Experts
Steven Wander
Steven Wander
The Wyzzyrd
Donald Griswold
Donald Griswold
Level 1 Expert
Are you a Samsung Projection Television Expert? Answer questions, earn points and help others
