Question about Ariens 34 In. Zoom Series Riding Mower
I need to fix or tighen my brake on my lawn mower
  • 127 Answers
MAKE AND MODEL?
Posted on Jun 26, 2009
My PB19542LT cranks and idles fine. But when you engage the blade it will not rev.
BlAde belt torque IS TOO HIGH It's reducing the engines running speed TO IDLE ALMOST check the blade brakes are releasing fully and the blade bearing are not tight or seem to move stiffly if the blade moved by hand ige ENIGINE OFF SPK LEAD TAKEN OFF PLUGS FOR SAFTEY AND IGNITION OFF TO AVOID ACCIDENTAL HAND CRANK ROUND START HALFWAY ENGAGE THE BLADE SYSTEM SO THE BRAKE SHOES RELEASE FROM THE PULLEYS AND THE DRIVE BELT IS LOSE NOT ENGADEGED FULY TURN THE BLADE AROUND BY HAND IF THECBLADEXOR PULLEY IS HARD TO TURN UNLESS ITS CLOGGEDUP BY GRASS DEPOSITS BUILT UP IN THE DECK OR BEARING HOUSINGS TO FIX IT WILL NEED DISASSEMBLING AND CLEANING OUT OF DEBRIS THEN PUTING BACK TOGETHER IF THE PULLEYS ECT ARE NOT CLOGGED UP THEN THE BEARINGS may need either lubricating with a race bearing grease compound or or if the blade is almost impossible to turn then the blade BEARINGS are worn out And WILL need REPLACING by mechanic the deck ajustment may also be to much and its over TIGHENING The drive BELTS slowing down the engine HOPE THIS HELP WITH THE DIAGNOSIS OF FAULT CHECK THE DRIVE SYSTEM FOR THE BLADES FULY
INCLUDINGVANYVTENTIONING PULLEYS ETC UNDER THE MAIN BODY OF THE MOWER INVOLDED WITH THE BLADE SYSTEM IF ANY PULLEY ENGAEGERSXSEEM TO BE STIFF OR SEEMS TIGHT WHEN THE BELT IS LOSSEND THE PULLY BEARINGS NEED CHECKING OR LUBRICATING ETC THE BELT COULD ALSO HAVE SHRUNK TOO SMALL IF THE MOWERS BEEN STANING STILL A LONG TIME IF THE BELTS HAS DEGRADED AND SHRUNK IT WILL NEED TO BE REPLACED
Jun 01, 2016 | Garden
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
Toro ss4235 release brake stalls when arm pushed in
bad check valve or buy pass screen dirty take to shop 100.00 for by pass to fix 100.00 for check valve to fix
Sep 03, 2014 | Toro Garden
Lawn mower brake cable
unhook both ends lubricate it and work it back and forth by hand
if it doesnt free up replace it
Jun 13, 2013 | Garden
Mower will not run wihen i take brake of
You need to post this question in the lawn mower section so the proper experts will see it.
Aug 18, 2012 | Husqvarna RZ4621 46"" 966659101 Zero Turn...
Husqvarna lawn tractor stalls when brake is
sounds like a safety switch most likely the one for your brakes
Jun 06, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
How to fix gears on riding lawn mower
First: check your drive belt. Don't have the product manual? Download it from the Sears or Murray website. Second: Check your clutch/brake linkage. The clutch may need adjustment. Procedure on manual. The clutch wears over time and needs to be readjusted.
Nov 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rear brake is sticking, how do I fix it
take the passanger side rear tire off & the brake caliper should be looking right at you looosen & take off caliper & there are 2 little dow pins in there that get frozen tap out with hammer drill holes alittle bit bigger add alille grease or assembly lube to it & reassemble
Jul 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mtd yardman mower== took it tto local repair man to fix for no brake and shifting hard. Now I have a brake but have lost the top 4-5 speeds. and it acts like it is going to slip out of gear. I have been a...
chances are he over tensioned the brake spring nut there is a specfic measurement from end to end of spring I know on the Castle garden it its 47.5-49.5mm. too much can damage the brake.Its more than annoying when repairs come back like this.
Apr 26, 2009 | Mtd LAWN MOWER PART # 17871D FENDER-REAR...
Hand break on the John Deere LTR 180 is stuck and
To temporarily fix you need to remove brake linkage to trans.If this works you need to get it to the dealer to replace park brake rod.
Mar 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Ariens 34 In. Zoom Series Riding Mower Logo
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
