Home | Mitsubishi | VS-60707 60 in. Rear Projection Television | Shuts off itself
Mitsubishi VS-60707 60 in. Rear Projection Television
Problem for Mitsubishi VS-60707 60 in. Rear Projection Television
Shuts off itself
By garysssr on Jun 26, 2009
shuts off itself
Best Solution
posted on Jul 19, 2009
Very Helpful)
Shandy1
Rank: Guru
Rating: 91%, 66 votes
I presume when you say it shuts itself off you mean it doesn`t actually come on, It goes to Standby, (Red light). If this is the case, It will probably be the power supply being turned off (Protection mode) by the microprocessor. Have you fitted extension loudspeakers with bad or loose connections? This was a common fault where customers made a bad job of connecting external speakers. I had this once with one set where the customer had a parrot which bit through the cable to the surround sound speakers. Try disconnecting all external connections first, If this doesn`t work, you have fitted speakers and there were taped joints in your wiring, you may have damaged the sound output chip. Other than that, you need an engineer. All modern electronic equipment including TV`s have an inbuilt safety feature to prevent the set from setting fire. It does this by having the computer which controls all the various functions (Including standby) permanently monitor all the voltages within the set. If a voltage is or goes low, possibly indicating a short circuit, the micro detects this and puts the set into standby. Some sets cycle or keep repeating the process of trying to get the set on and then gives up after a certain amount of cycles if the fault does not clear. A good example of this is when there is a very bright screen, the micro could shut the set off thinking the power supply is getting low. Basically what I`m saying is, it`s a workshop job with engineer if non of the fore-mentioned faults exists. Ian
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jun 26, 2009
Very Helpful)
rulds2008
Rank: Guru  Televisions & Videos  Expert
Rating: 86%, 1028 votes
I need some clarification what you mean it just shuts it self off,
First check the power supply inside
if that is good something is heating up causing it to shut down. Thanks
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Oct 20, 2009
Not Rated)
barceloco
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
need resolder bad conections in crt yoke conections.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi VS-60707 60 in.
Questions and Unsolved Problems for Mitsubishi VS-60707 60 in.
Do you recommend Mitsubishi VS-60707 60 in. Rear Projection Television?
Answer
Answer
t.v. will not stay on. when i turn it on i hear a double clicking noise and the power light flashes... (More)
Answer
i have a 60" mitsubishi projection tv model vs-60707.turns on and plays fine for awhile then... (More)
Answer
I have a vs 60607 tv / input menu code is 1 2 lights come on for 1 sec then dim good audio
Answer
I have horizontal flickering lines that would come, and go. We blew the dust off the components with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi VS-60707 60 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
