Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Just bought a used 1991 Viking pop up camper trailer. The heater is just blowing out cold air. Do these heaters have pilot light? What could be wrong?
2 Suggested Answers
machinetech7
  • 1344 Answers
SOURCE: I have a viking vcbb363. Does the evapotator fan blow into the freezer or blow back so the cold air goes up to the refridgerator?
Not sure exactly what the situation is I'm going to give you a detailed overview on how the system works that way you'll be able to isolate the problem. Your machine is a single compressor unit, meaning that even though there are two seperate sides, the freezer and the refridgerator, they do not operate independantly. The sealed system, which is what cools the machine, has two parts, a high side and a low side. The high side is located under the machine and consist of a condensor, for which freon is pressurized back into a liquid and passed throug the compresoor to be released as a gas into the evaperator, the low side. This is where the freon is at a cold state. Ok, now that you have the bare basics of a sealed system, we move forward. The Evaporator is located in the freezer side, behind the freezer wall. As freon goes through the evaporator, a fan, called the evaporator fan, is located above it and circulates air throughout the freezer compartment. Also, an airway connects the freezer to the refridgerator, usually top right of freezer, or top left refridgerator on side by sides and through the freezer floor on top mount models. This means the freezer cools the refridgerator side. ****First check point**** Is the fan running in the freezer? This would cause the freezer not to cool as well but also a rise in the refrigeration side would be noticed. As freon goes throught the evaporator, which is made of aluminum, the temperature levels are well below the freezing point, so frost and ice will form on the coils. Over time, this kind of build up would form a blockage, not letting air be drawn from the bottom of the coils by the fan to circulate the cold air. To prevent this from happening the a defrost heater is installed to thaw the ice away and comes on every 6-8 hours. This is initiated by the defrost timer, or in some machines an adaptive defrost control. The heater will be located at the bottom of the evaporator because hot air rises, getting maximum effect. A third part to the defrost system, the first two being the timer and heater, is a bi-metal,or terminating thermost. Its called this because when the thermostat is cold, the metal inside it constricts making a pathway for electricity to flow through to the defrost heaters so it can get hot, and as the heat rises and the ice melts away, the terminating thermostat will warm up, and the metal will expand causing the path of electricity to be broken, turing the heaters off. This is to prevent any high temperature situation from happening, like melting plastic or even a fire. If any of these parts fail, the machine will nit defrost. ***Checkpoint two***** Do you see any ice build up on the freezer wall. This ice will be completely across the back wall. Most signs of defrost problems are noticed first by a rise in temperature on the refrigerator side first. The above can be assessed with a quick look and listen. If no frost is present and the fan is running you can rule out the above. ****Please not that ice build up on just a small section, for example, upper left or right corner only is not a defrost situation but a sealed system issue, caused from low freon or a restriction in the lines and a EPA certified technician should be called.****** The last thing you should check you'll need to pull the machine away from the wall and remove the lower panel to gain access to the compressor area. What you are checking here is to see if the condensor fan motor is running and that the coils are somewhat clean enough for air to flow across them. The fan draws air from across the compressor and through the coils helping to keep the compressor temperature down and also to evaporate the water that is drain when the machine goes into defrost. Rule of thumb is if the compressor is on the fan should be. If the fan isn't runnning the heat from the compressor will be transferred to the machine and notice first on the freezer more so than the refrigerator. ****checkpoint three**** IS the condensor fan running? Are the coils clean, and can you feel the air from the fan with your hand placed on the opposite side of the coils?
The refrigerator side is usually where your defrost timer, discussed earlier is located. Also on this side is where your temperature control, or controls , are located, These controls are what are called thermostats, and have a direct line to the compressor. This means when the temperature has reached the desired setting the thermostat will kill power to the compressor in the same manner the terminating thermostat does with the defrost heater. Some models have a temperature control thermostat for the freezer and the refrigeratot, but some only for the refrigerator. The most noticeable sign of a thermostat being bad is the food in the refrigerator side will freeze, usually on any setting or the machine won't come on at all, including the fans. Problems are usually noticed on the refrigeratot side first. The last thing to discuss is The freezer and the refrigerator both are rising in temperature, but the fans are running, etc. Normally in cases like this a humming sound followed by click is heard or sometimes just the click. The humming sound is the compressor trying to start but failing and the click is the relay breaking contact. On newer machines, especially ones that fall under the whirlpool umbrella, the compressor relay, also called the start device has failed and needs to be replaced, but also the compressor itself could be bad. Well, thats the basics. I know it's long winded but I wanted to put something that you could print out and use as reference. Good luck.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Jun 07, 2012
How do I get my heater to blow hot air?
I assume this is gas . induced draft blower or ignitor.
Apr 30, 2014 | Goodman GMS90703BXA Heater
Electric heater problems.
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
Jan 28, 2014 | Open Range 2011 Mesa Ridge MR243F
SW4P Pilot Water Heater 3 Gallon Trailer Camper RV
These systems use "flame rectification" to sense or prove a flame or pilot flame exists thus it is safe to continue or transition to main burners if a system with a pilot light.
The AC spark is rectified to a DC signal by the flame as the AC current passes through the flame, the flame being a poor conductor only a small amount of DC signal is sent, in the milliamps, so it is not too difficult to interrupt the signal and disrupt the operation, it is doing this for safety.
What you can do is clean the surfaces where the pilot assembly meets the casing and burnish this path clean back to the ignition modules ground or burner ground terminal, there may be a flame sensor too, in this case clean it with 0000 steel wool it is just a ground rod and does not wear out but will build a film that can disrupt the weak DC signal.
Nov 04, 2013 | Suburban SW4P Pilot Water Heater 3 Gallon...
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Jan 17, 2013 | Empire DV-35 Heater
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
Pliot is lit...no heat
check to see if voltage to gas valve if no replace or check wires
Jan 06, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
455 people viewed this question
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
