SOURCE: Vent control
You have a vacuum leak.Defrost is the default postion(no vacuum).
See if you can locate the small black vacuum line that goes inside the vehicle on the passenger side near the heater core. The trace it back,should see it going to a canister then to the intake manifold.Make sure it is not disconnected or broken somewhere.
SOURCE: heater is blowing but its cold air not hot air 2000 expedition
Make sure the heater core is in the open position by using the shut off valve and turning it to open. next, you may have a malfunction in the direction door the directs the air flow in the dash. a lever may have become lose or separated. may be a bad servo motor not directing the door to move to the heater position. i would start by checking that shut off valve first on the heater core.
SOURCE: I have a 2006 Ford Expedition. The Air
you have a vacuum loss to the ac control head, the motors that divert air are vacuum operated, if you loose vacuum the system goes to defrost for safety reasons, the vacuum comes from the engine, then goes o a plastic vacuum tank under the hook start there, it is a 3/16 id hose.
SOURCE: heater blows cold air have replaced the thermostat
sounds like the controller went bad use temp checker see what your temp is at inlet of heater core from hose
SOURCE: 2001 ford taurus wagon/air only flows through defrost vents
you have a vacuum leak check vacuum lines
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
These will help.
Thanks.
