Question about Blueant X5 Wireless Headset
X5 microphone not working with skype
Can't seem to get x5 microphone to work when using skype, headset is receiving ok, thanks
Microphone doesnt work with skype
I've heard of this problem alot, I took 10 minutes today with my friend with this headset to figure out a fix.
From what i can tell, Skype doesnt pick up the Microphones input.
The only solution I could figure out so far has been this.
A voice changing program called MorphVox Pro (by Screaming bee) offers a Trial.
If you download it, and set up your microphone on this to work, You can then in skype select the MorphVOX Pro as your microphone, and you can use this chat program to work with your headset.
This is only a temporary fix But it is a step in the right direction, I'll be forwarding my email to Razer later to try and get some updates for the headset.
Best Regards
Ricky.
Feb 09, 2013 | Razer Chimaera 5.1 Wireless Gaming Headset...
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
Can I use a plug in microphone to use skype on a Dell precision M70
I haven't set up Skype before, but it seems quite reasonable that if the Sound control panel is set to use the external microphone, that would work. Have you checked to see if the sound input is set to an internal microphone built into the laptop, or a line-level input? That could be your problem, especially if no such microphone is present.
Nov 25, 2011 | Computers & Internet
New user with Blue Parrot B250XT headset. Using it on Skype and PC with iogear bluetooth dongle, all seems to be properly configured. Tested the audio quality from the microphone and it is garbled. ...
It seems that there is a physical problem with the microphone of that headset, It rarely happens but it does, even brand new units sometimes would have defects.
In windows there is a sound recorder feature that you can use so you can try recording your voice from the headset and check if it will be garbled.
you can also test the device on another equipment, Pair it on a mobile phone that is bluetooth capable and try calling or receive a call and check if the same result would appear.
If the same happens for all these steps, if you have just bought the headset you would want to bring it back and ask for a replacement unit or a refund and get a different model.
Hope this helps!
Aug 24, 2011 | VXI Corporation Blueparrott B250-XT...
Logitech ClearChatStyle Headset + Skype + Vista Premium Home
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Aug 15, 2009 | Logitech ClearChat Stereo Headset Headset
Clear chat mic doent work
in skype go to tools>options>audio setting make sue the microphone is logitech and the green bars should start moving as you talk.
if no logitech appears or the mic is not producing sound. call logitech for warranty info. if the mic is producing sound below is "make a free skype test call" to see if the program is transmitting.
Jul 18, 2009 | Logitech ClearChat Stereo Headset Headset
Hi, I am looking for a good headset to use with Yahoo to talk to my daughter in Italy. Seems most I see are for Skype. Thanks
I absolutely loved my Lifechat LX-3000 from Microsoft. very clear sound and the microphone didnt destort my voice when I DJ online.
Dec 20, 2008 | Microsoft LifeChat Stereo Headset with...
CONNECTION TO SKYPE AND MICROPHONE
If you are using an external headset your Laptop should pop up the RealTek Management Window prompting for the device connection that the laptop has just detected and you will just click ok for mic and headphone and you are ready to run. The microphone on the laptop plataform and internal speakers work as well, I had no problems whatsoever.
Nov 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computer does not recognise the headset
might not have it plugged into the correct jack on the back
Jan 06, 2018 | Altec Lansing Radio Communications
Blueant X5 Wireless Headset Logo
Top Blueant Radio Communications Experts
aliasger yq
Paul Chapman
Paul Chapman
Greg P
Greg P
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
