Question about Logitech Harmony 659 Wireless Advanced Universal Remote - 966179-0403 Remote Control
Remote goes too fast through channels
When trying to change channels it will not change or will change but very slow. Most of the time it skips channels , say from 500- 504. My remote is only 8 mo. old . I changed batteries , to no avail. Help Help.
4 Suggested Answers
SOURCE: changing channels has become very slow.
Have you tried updating the firmware and making sure the inter-key delay for the device that you use to change channels is set to 0?
Posted on Mar 09, 2010
  • 101 Answers
SOURCE: Harmony 1000 never worked right; out of warranty
email in they will help you there. I have never been turned down by them! i have been out of warranty for about a year
Posted on Apr 20, 2010
  • 71 Answers
SOURCE: When I change TV channels
Point the remote directly at the TV and push the button gently.
Hope this helps.
Posted on Feb 24, 2011
  • 422 Answers
SOURCE: How do I change the configuration to stop it
reconfigure it with the pc software.
set it with the correct tv/settopbox model and try again.
Posted on Jun 12, 2011
0 characters
1 Points
I get a download message telling me to hit main for three seconds or skip. When I hit main nothing happens and when I hit skip the remote freezes. Cannot perform any functions and unable to change...
check your batteries to make sure they are good. if they are good you may need to default the remote and reprogram. if this doesn't fix it you will need another one
Jun 08, 2014 | Universal MX-450 Remote Control
Changing channel goes too fast
Try pushing the button once for each channel change instead of hgolding it down
Apr 19, 2013 | Philips Remote Controls
I have a phillips universal remote and I need the code that matches to a Liteon dvd player and recorder. Model LVW-1101HC1
The codes that I have are for the LVW-1101 ( and possibly 1105). The remote responds to the JVC remote code [0623] but the individual command buttons are scrambled and need to be programmed in-unless you have the remote w/ learning):
266-play 286-TV (as source)
292-Fast Rewind 296-Cursor Rt.
301-Fast Forward 304-Record
316-1 325-7
326-Cursor/Channel Up 328-Timer
329-0 330-Menu
364-Setup 365-Select
367-Stop 368-Previous Track
369-Cursor/Channel Down 385 Commercial Skip
389-Source 390-Next Track
413-Cursor Left 416-Display
417-2 420-Open/Close
421-3 427-4
431-Top Menu 433-Navigate Menu
452-5 453-Easy Guider
454-9 455-Power
459-6 462-Tools
474-8 479-Pause/Step
500-Channel Editor
Finding the codes is not hard-just tedious.
Aug 18, 2009 | Remote Controls
Channels are skipping
Turn the power off to the receiver and let it run its course. It should download a new program guide at this time. Another thing is to make sure you are on ALL SUB on the guide as opposed to a favorite self created guide.Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
TV stuck on blue video screen
This usually happens when you are on a source that doesn't have a signal such as a channel with no signal or an AV input that is not connected.
You should look for a button that has TV/VCR or TV/VIDEO on it. I've guessing that you've already tried to change the channel but if not try that.
Last ditch effort in that case may be to unplug the TV for a few secouds. Warning- this may wipe out any settings you have entered such as the channel programming (which channels to skip while surfing) but along with that goes the blue screen.
Jan 11, 2009 | RCA Universal Remote Control
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
codes forzeniyh remote toshiba-tv and magnavx-vcr
Feb 19, 2008 | Zenith DBZN-311 Remote Control
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Remote Controls
Remote Controls Logo
Top Logitech Remote Controls Experts
bill tarkulich
Level 1 Expert
Ron Dufek
Ron Dufek
Level 1 Expert
Are you a Logitech Remote Control Expert? Answer questions, earn points and help others
