Question about KitchenAid 32 in. KECC502 Electric Cooktop
One of the dials (the pot) doesn't work anymore. How easy is it to replace for a DIY?
  • 67 Answers
It's called a rheostat -no it is not hard to replace ---open the breaker, of course. write down the wiring if you think necessary---then remove and replace. you might want to check/compare the rheostat to one of the others to verify it as the problem
Posted on Jun 26, 2009
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
My Dacor PGM365-01 main burner continues to spark after I place a pot or pan over it. I just replaced the spark module - still happening. Valve? Micro-switch? Clean the burner?
What is your altitude?I have the same problem and was told by Dacor that I should have the high altitude version. I'm at 5000'
Feb 14, 2015 | Dacor Cooktops
One plate in Bellini induction cooktop continues to flash with a pot on it, yet the pot works on the other 3 plates. How do I fix?
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
Feb 13, 2012 | General Cooktops
Oven willnot turn on....broiler works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 07, 2010 | GE Profile JGP636 Gas Cooktop
Pot stuck to cooktop
Did you find that it was stuck after it had cooled off? A vacuum was probably created between the pot and the glass top. You could try twisting the pot, leaving it for a while, or heating it up again.
Apr 11, 2010 | GE Profile JP930 Electric Cooktop
Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Dec 26, 2009 | Cooktops
I have a corning 3+1 cooktop and the burners wont turn off .
replace the switches, its easy to replace,call the service center to get the part to replace,if very expensive,buy an ordinary switch,put in the wire of ur unit.every time u use it turn it,or buy a plug or an adaptor have switch at the side,make sure the adaptor is fit in ur unit.
tnx gerbee
Sep 04, 2009 | Cooktops
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Miele KM443. Elements switching on and off every 5 to 7 seconds.
as far i know it is normal if u put at high control after a sec,the sencor control is turn off then a sec again it open coz of the sensor, design the sensor for not overheating the hob.it is normal try to position the control in in not a max position.or the pot u use is exactly in the circle or bigger dont put a small one in the bigger hole of ur elctric hob.tnx
Nov 23, 2008 | Miele 30 in. KM443 Electric Cooktop
Jenn-Air JED8430BDB blowing fuse following ceiling fan work ...OUTside!
You have posted this to a public webpage that has 7 million visitors and is nothing to do with your electrician 'Eddie'. You have also posted your telephone number and email address to those 7 million viewers.
Feb 27, 2017 | Jenn-Air 35 in. JEC9536 Electric Cooktop
KitchenAid 32 in. KECC502 Electric Cooktop Logo
187 people viewed this question
Top KitchenAid Cooktops Experts
vince
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
