Rice on the very bottom of the steamer pot sticks and turns brown . should I be adding more water to the pot when I make rice?
SOURCE: cooking rice
very easy 6 cup s rice 6 cups water
it means equal proportion...try it to believe
SOURCE: how do you cook light brown rice in the zojirushi rice maker
Hi! Thanks for using FixYa - here's the instruction manual:
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/ns_pc.pdf
And here's your recipe guide too!
http://www.zojirushi.com/servicesupport/manuals/manual_pdf/nsxac05_xbc05_recipe.pdf
Please take a minute to rate my solution!
Gregg
SOURCE: Hitachi Rice Steamer Instructions needed
I have a book for Hitachi chime o matic food steamer/rice cooker models 6103, 5083, and 4053. I can type out the instructions for you if you want me to. Diane
SOURCE: The rice dries out in the "keep warm" mode
You have a strange problem. I use my rice cooker often and the only thing that I can think of that may be casing your problem is if the steam vent is clogged. A clogged vent would cause the steam to condense and run to the bottom.
With the machine empty of food, you could try pouring hot water through the vent to see if this clears any clogs. If it does not, it could be other problems that I can tell you will cost more money to fix than to replace with a new Rice cooker.
Good Luck.
SOURCE: rice cooker spits rice juice all over counter
I had the same problem when I cooked brown rice in my rice cooker! I found that adding a tablespoon of butter on top of the cooking rice solves the problem. (A friend told me it works when cooking beans in a pot, so I figured it would help with rice too, and it did!)
