The washer makes a noise. The agitator does not move. The bucket/basket does not turn. The water pump does pump water out of the bucket/basket.
  • 1 more comment
  • graine Jun 26, 2009
    My washer is a Kenmore Series 90 model number 110.28912790.
    I have a Kenmore Series 90 washer model number 110.28912790. The washer pumps water but does not spin. The basket/bucket is locked into place I could not get the basket to spin by trying to turn it by hand.
    I have a Kenmore series 90 110.28912790 the basket will not turn it appears locked into place and it makes a loud noise when the lid is up or down. The water pump does pump the water out. How do I get the back off? to inspect. I have cleared the hoses and drain hose but is there some trick to getting the back off?
  • Washing Mach... Master
  • 3,866 Answers
This would be mostly cause is the belt or motor not moving the agitator I would check both.
Check belt see if its slipped or is broken, check motor if the belt is fine. Ether one of these would be the cause.
Thnks for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 26, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Jun 26, 2009
    yes you start with the back panel screws the rest should come secound nature
  • 351 Answers
What brand and model number? you can vist whirlpoolpartssurplus.com and talk to mark free via phone...i will be here all night ... lets get this fixed...save you some money
  • Mark Nichols Jun 26, 2009
    Will the tub act like it wants to spin? do you have the lid switch activated? i am thinking the lid switch is bad if it does not do nothing.... if it does try it will be your spin basket drive
What's the cause of my washer's agitation and noise problem?
Possibly a bad basket drive. Or something is wrapped around the shaft under the tub or something is in the pump.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Washing Machines
My washing machine stop working half way through a cycle. Water is still in basket. The timer just make a huming noise. I can get the machine to move back and forth but not spin nor train the water. ...
Unplug machine, then use a putty knife to push the two retaining clips in, located in the seam between the front panel and the washer's top, about 2 or 3 inches in from each side, while you gently pull the front panel forward. Now, take the hoses off the pump (be ready to catch some water with towels or buckets, depending on how much water is left in the tub) and remove pump. Clean out any obstruction in the pump, like rubber backing from a rug, filling from a pillow, a nail or screw from a pocket, etc. Re-assemble pump and hoses, connect power and test.
Mar 06, 2011 | GE WDSR2080D Top Load Washer
Im able to start a load, water fills, washer agitates and rinses just fine. However, once the spin cycle starts, the washer starts to make an extremely loud noise (similar to when it is off balance) and my...
If you can move your basket up and down your spinal is broke at rear of basket..You would need rear tub and inner basket for that repair......If this helped please vote need more help please ask...
Feb 03, 2011 | Kenmore 24032\24036 Top Load Washer
I have a Maytag washer that the agitator is not working , I makes a squealing noise, How do I repair this? Thanks
Your problem may be a seized water pump with the motor turning the drive belt on a water pump pulley that is not turning (belt squealing). Or the noise could be originating from a water pump that has a noisy/bad bearing. If the pump pulley is turning and making the noise, you may be able to lubricate the pump shaft with some quality shaft lubicant (no guarantee that the noise will cease)! If other problem, contact an appliance service company.
Feb 20, 2010 | Maytag Washing Machines
WASHER MAKES LOUD NOISES DURING THE AGITATION CYCLE. THE MACHINE IS LEVEL
The first thing I would request you to do is lift up the washer from the front, remove the belt and check the pump by rotating the pump pulley manually. If does not move freely then replace the pump. Also, look into the tub as it agitates. Does the basket turn in the opposite direction as it agitates? This would indicate a bad brake. You probably have bad brake shoes, or ones that are oil soaked. Pull front panel and check above the tyranny for a bad seal.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Washing Machines
Won't agitate and makes loud noise during this time, it spins
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Dec 04, 2009 | GE Washing Machines
Maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Sep 29, 2009 | Maytag Performa PAV3200
Agitator does not spin, machine is very loud
Servicing the Tub and Agitator
©2006 Publications International, Ltd.
Replace a damaged agitator
with a new one of the same type.
Unscrew the cap on top of the
agitator and pull straight up;
the agitator should lift off.
The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
Servicing the Water Pump
Of all washing machine parts, the water pump probably takes the most punishment, because it is constantly in use. When the pump fails, you can hear or see the trouble: a loud rumbling inside the machine, or a failure of the water to drain out of the tub. Here's what you can do to fix the problem:
Take the pump apart and clean
away all debris inside the pump.
Also clear away debris from
the water tubes.
Step 1: Check the drain hoses to make sure they are draining properly. Remove the water supply hoses from the back of the washer. With long-nosed pliers, extract the filter screens from the valve ports in the washer or from the hoses themselves. Wash the screens thoroughly. Then replace them and reattach the hoses. If the machine still rumbles or doesn't drain, examine the pump.
Step 2: To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the bottom of the machine, but with the unit tipped on its front it's easier to remove the pump through the back than through the bottom of the washer.
Step 3: Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Then try the machine again to see if this kinking was causing the problem. If the machine still doesn't drain, you'll have to remove the water pump.
Step 4: To remove the pump, loosen the bolt that holds the drive belt taut and move the washer motor on the bracket to loosen the belt. Move the motor out of the way and unbolt the pump; it's usually held by two or three hex-head bolts located on the bottom of the pump housing. As you loosen the last mounting bolt, support the pump with your hand. Then lift the pump out of the washer.
Step 5: You should take the pump apart if you can, because the trouble could be lint, dirt, or pieces of cloth or paper clogging the pump impeller. Clean away all debris inside the pump and clear any debris out of the water tubes. Then reassemble the pump. Hook up the pump again and test it. If cleaning the pump doesn't put it back into working order, or if the pump housing can't be removed, replace the pump with a new one of the same kind.
Step 6: To install the new pump, set it into position and connect the mounting bolts to the pump housing. Move the motor back into position. Tighten the drive belt on the motor by prying it taut with a hammer handle or pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
Step 7: Reconnect the hoses leading to the pump.
Or Replace tighten Drive Belts and Tightening Pulleys
Aug 30, 2009 | Washing Machines
Basket won't move-noise
do you notice if it agitates?
if it doesnt agitate it is just a simple coupling
if it is making a humm noise its the motor
if a LOUD rumble ONLY on spin cycle, its the basket drive assembly and the clutch.
May 29, 2009 | Whirlpool LSQ9610L Top Load Washer
Front loading washer basket is loose and pump is making noise
The loud sounds you hear when the washer is on is coming from 5 possible sources 1. unbalance wash load, 2. a washer that is not level, 3. a broken agitator, 4. a blockage in the water pump, and 5. a worn transmission.
Solution, balance your load, level your washer, removed the hoses from the water pump to remove any blockage. If these solutions don't solve the problem contact a service provider to service your agitator and or your transmission.
Good luck
Aug 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
