Question about Kenmore 3.5 cu. ft. King Size Capacity Top Load Washer
29522800 Kenmore Won't wash.
29522800 Kenmore. Brand new. Just hooked up. Fills with water. Makes buzzing noise and does not go into wash cycle.
  • 351 Answers
Ouch def get a new one or get warranty to come out could be bad news
Posted on Jun 26, 2009
My washer fills up with water and quits after that, it makes a buzzing noise when it should start its cycle. what can i do to fix this? it is a kenmore series 80
This could be a capacitor, which gives the motor the 'spark' to start, or the motor itself. If you try to move the empty machine's basket by hand, is it hard to move or does it spin freely?
Joe
Aug 29, 2011 | Kenmore Washing Machines
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Machine stopped in the spin cycle, now only makes noise.
Be sure BOTH fill hoses are hooked up and TURNED ON. What happens is (commonly) hot and cold hoses are installed reversed, and no one really notices.....Then Dad gets a big hot water bill and turns off the HOT water (actually hooked up to the cold input on the machine), so when the machine gets to the rinse cycle, no water comes in, and it waits patiently (forever) for water which never comes. The buzzing is the water valve. This is the most common problem.
Dec 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
When starting a new cycle no water fills in. It just makes a buzzing sound
An inlet valve can buzz normally...However, if water is not flowing it probably means that the inlet valve is faulty..Make sure that the filters on the inlet valve are not blocked..If they are clear it's probably a faulty valve... Good Luck....Nomess
May 13, 2010 | Washing Machines
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Ammana nav8805e
If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Washing Machines Logo
290 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
