Question about Copystar CS-1510 Copier
Fault has joo on screen and can't get it off,,,,no jams and toner is full
  • Kevin G Nov 06, 2007
    switch was out of position and stuck, thank you
    Sniper:
  • 56 Answers
Paper Jam. Inspect paper path,maybe there is some piece of paper on the sensor actuator.Switch off machine,wait 10 seconds and switch on.Also check all doors,covers are properly inserted/closed
Posted on Nov 06, 2007
Error code sc23-03
DRUM MOTOR ERROR.
Check the cleaning blade the cleaning roller or the toner recycle system driven my the drum motor. to check the cleaning blade and toner roller remove the drum cartridge. Drum could flipped the cleaning blade toner roller could have jammed or motor bad great jam. worst case control board fault.
Mar 13, 2014 | Konica Minolta 7255 Lower Fuser Picker...
Red Light comes on and wont print
There is a lot of faults that cause the red light to turn on, toner cartridge empty, waste toner tank full, paper jam, imaging unit replacement, etc. The only real way to know what the problem the printer is seeing is to use the smartpanel utility on your PC. It will show you what the printer is reporting and how to correct it. Hope this helps you.
Mar 09, 2011 | Samsung CLP 300 Laser Printer
When I turn my printer on, the red light stays on and I can't print
Are any of the toner lights lit? Then the problem is you are out of that color toner and must replace it.
If the toner lights are off, then the printer has an error that must be corrected. Check for a paper jam, an open cover, no paper in the tray (or not being picked up by the rollers), the waste toner container being missing or full.
The other errors that could be at fault are service errors: LSU (laser unit) error, fuser error, or ITB
error. For these, you need to contact Samsung support for the part numbers. The fuser should last 100,000 pages. The ITB has an expected life of 60,000 black and white pages and 15,000 color pages. Samsung recommends these be replaced by a certified technician.
The unit will not print until the fault is fixed.
I hope this helps.
Sep 30, 2010 | Samsung CLP 300 Laser Printer
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
I have a total of 10 HP Color LaserJet 4650 printers, and 7 of them have the following problem: they jam at the fuser whenever a full-color picture, photo, or slide is sent to print (especially ones with...
This jamming has to do with third-party toner cartridges being used. I had this problem using Xerox toner cartridges and found that I would have no jamming if I used at least 2 hp-brand toner cartridges and the rest Xerox. I then used a different brand of 3rd party toner cartridges that would not jam as long as just the black cartridge was a genuine HP black toner cartridge. This issue has been confirmed even by the manufacturers of the generic toner cartridges. Hope that helps!
Oct 15, 2009 | HP LaserJet 4650 Color Printer
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Paper jam
A toner certainly can cause a paper jam. However the jam would be located in the area of the cartridge. Easiest way to check is swap the new with the old or a known good toner and see if the problem follows the toner.
hope this helps
Mar 17, 2009 | HP LaserJet 1020 Printer
ERROR EE2 WARNING
one bad toner has jammed or toner drive clutch has fault. open right cover and you can see witch clutch makes noise. or toner drive moter has problem.
Sep 05, 2008 | Brother HL 2700CN Laser Printer
System Fault
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Copystar CS-1510 Copier Logo
82 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
