My room is not getting cool. the air conditioner is brand new, out of the box, perfectly clean
  • 10,865 Answers
It sounds like your air conditioner isn't big enough to cool the room you have it in. SInce it is brand new return it and get a larger one. Tell the store clerk the dimensions of your room and err on the side of bigger as opposed to smaller that the dimensions call for.
Posted on Jun 26, 2009
New kenmore 25,000 won't cool only fan
Sounds like bad wiring job or didn't get charged with Freon at the factory. Return for a new one.
May 06, 2014 | Kenmore 25,000 BTU Room Air Conditioner
Brand new kenmore air conditioner 18500 btu, there is no place for the water to drain, no drain plug? water is getting high... model 70181
The new Room A/C's do not have drains as it uses the condisation from the pan to help cool the coils this makes the unit more effecient.
Sep 01, 2011 | Kenmore Room Air Conditioner
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
BRAND NEW AC IS FREEZING UP
Temp set to cool. shut it down for a hour or so . close all unused rooms. set tstat to mid range and start it up again . when it cycles off and its still to warm in the room trun the stat down tell it comes on again. Also check the filter and make ceratin it is clean.
Jul 15, 2011 | Haier ESA3109 WallWindow Air Conditioner
Insufficient cooling with window air conditioner
The air conditioner should be big enough. It is hard to say whether or not the 46-47 degrees is right as you did not give a room temperature. The first thing to do before installing a used unit is to thoroughly clean it. Use your garden house to rinse both the evaporator and condenser coils. Also ensure the filter is clean. If the unit is still not cooling properly it likely needs a shot of refrigerant. Beyond cleaning the unit I would not recommend other do it yourself fixes.
Jun 27, 2010 | Heating & Cooling
Room air conditioner not cooling low enough
It may need cleaning, if it cools when you turn the thermostat down it does not need refrigerant, the unit may have a thermostat our of caliabration.
May 27, 2010 | Kenmore 71121 Air Conditioner
My air conditioner is no longer cooling. When I try to change the setting on the panel to "cool" it does not light and the room remains the same temperature.
Please check the temperature its set on, Please check if the compressor is working, if everything is perfect then lastly please get someone to check if your air conditioner contains the required minimum gas for cooling.
Sep 07, 2009 | Heating & Cooling
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 02, 2008 | Fujitsu 18C1 Air Conditioner
SHARP AIRCON BRAND NEW - NO COOL AIR
The problems are to numerous to guess. a wire off, a bad control.
I would suggest you return the unit to where you bought it, and get a replacement or in some cases there is a warranty phone number on the paper work you can call. According to the manufacturer they may send a service tech. out to make any repairs. If it's under warranty let the manufacturer honer there warranty. you'll be glad you did.
May 15, 2008 | Sharp AFR120FX Air Conditioner
Heating & Cooling Logo
116 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
