Question about Microsoft Wireless Laser Desktop 4000 Keyboard/Mouse
How can i get my micosoft wireless keyboard be recongized on my computer?
My key board is not reading my numbers and on re start it keeps saying key stuck
Turn it over and smack it on the back. See if the problem goes away. If you have spilled something on it that was sticky you can use armor all to clean it. Otherwise replace it. Generic keyboards are not expensive.
May 14, 2014 | Lenovo Keyboard
Micosoft Wireless Laser Keyboard 6000 v2.0 Model 1074 & Micosoft Wireless Laser Mouse 5000 v1.0 Model 1058
To make them both work together you need IntelliPoint for the mouse and IntelliType for the keyboard and system no newer than Windows 7. For explaining incompatibility issues see:
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/microsoft-wireless-laser-mouse-5000-v10-model-1058/692bf1f8-ce34-4937-8c8f-a78cff379787?rtAction=1483615029455
Feb 24, 2012 | Microsoft Computers & Internet
I need a driver micosoft Keyboard 1.1 and mouse 2000 for window 7
Mouse and Keyboards have a generic driver that Windows uses to operate. Can you tell me the manufacturer and the model number which normally could be found on the box of the keyboard and mouse.
Are these wired or wireless keyboard and mouse? are they connected via USB or PS2 port?
Jun 09, 2011 | Computers & Internet
My medion 95924 keyboard is locked. I am unabe to
Does the keyboard work in Dos mode or when you boot up goto set up and see if you can use keyboard to adjust settings
Nov 01, 2009 | Medion MD 96340 Laptop
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
"Assign keys" Dialog Box.
What I would suggest is reinstalling the keyboard software from Microsoft. This is better than resettnig the defaults as it will mend any issues the keyboard software is causing, which is probably the case. When you go to Control Panel and uninstall the keyboard software. that is to say you do this once you have the CD or have downloaded the latest software version from micosoft.com/downloads You may find that when you click on the keyboard software to uninstall it in Add Remove that there is another option titled Repair, if so, choose that and let the OS repair the installation.
Kind Regards,
Worldvet
May 28, 2008 | Microsoft Wireless Optical Desktop Pro...
Keyboard locks on Notebook
You should try downloading KEYBOARD Driver. TouchPad refers to MOUSE.
Sahaja Yoga is the Mahaa Yoga and is the Only Solution to all the Problems of World.
Apr 02, 2008 | Computers & Internet
Connection to the internet.
If it worked for a long time then stopped, there might be a new wireless transmitter around. XP is awful at picking a connection back up once it drops. Does it drop less when the computer is closer to the transmitter? You might try changing the channel that your unit is broadcasting on.
Mar 17, 2008 | Hawking Wireless-G HWR54G (603992506064)...
Computer doesn't recongize my mp3
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Jun 23, 2007 | SanDisk Sansa c140 MP3 Player
Microsoft Wireless Laser Desktop 4000 Keyboard/Mouse Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
