Question about Xantrex Technology Heart Freedom 20 12 Inverter
We just bought an rv with a freedom 10 in it. It works fine until a load is put on it, then it goes to FAULT on the remote and red lights start blinking. We think it's toast! HELP!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
It is and it is no consumer serviceable hs to be sent to nj to be even looked at only thing you can do is check battery voltage
Posted on Aug 01, 2009
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
How do you know remote is working?
Fresh batteries in remote? Will AC turn on by manually at ceiling assembly? Little green or red light on at ceiling assy? Have you checked Carrier site for manual to download?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
Freedom 20 Inverter/Converter Charger installed on Alpenlite RV. When remote switch for solar use (2000 watt) is turned on, all 110 system is energized. Turn solar switch off and voltage check at...
Second Freedom 25 inverter/charger...first one repaired, this one went to fault...started microwave on fire, fried the satillite receiver and possibly other components....installing a Mangnum....."do not let anyone rebuild the Freedom 25" First time about $900.00 to rebuild...this time about $9000.00 with components it fried. Fleetwood LLC Corporate knows of problems and only offer to sell you the conversion kit for about $4200.00....bankruptcy sanctifies previous problems "they" left with us.
Oct 27, 2010 | Xantrex Technology Heart Freedom 20 12...
Freedom Combi inverter/charger stopped working with the remote inside the RV. Replaced remote but still didn't work. I have to press inverter button inside RV, go to inverter outside RV and press...
Sounds like the link between the inverter and the remote is bad. Chaffed wire, broken wire, etc may be the culprit.
You should still have the shorting jumper that came with the Freedom. Put the jumper into the AUX port, and you should now have local control of the inverter. If so, then replace the wiring between inverter and remote.
Aug 08, 2010 | Xantrex Technology Xantrex 458 10 12...
Wiring Freedom 20 inverter
make sure your new inverter is made for 220 volt supply as that is what the red wire represents. its the other leg of a 220 circuit and should not be connected to your new inverter until you read the manual to see if it is designed for this and if so how to wire it in. it could cause you are the unit serious harm if you connect a 110 inverter to a 220 circuit. consult an rv repair shop or a good electrition if you cant find the needed info. it may actually be printed on the side of the inverter as well.
May 27, 2010 | Xantrex Technology Heart Freedom 30...
Freedom 20 Inverter / Charger
1997 monoco dynasty and the invorter heart interface freedom model 20 the problem we are having is the we don't get any powere from the electric outlet and the lights don't work and there is a reading in side on wall that tells you about your electricity and it reads overload my # 817-614-7576 donna
Feb 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Behaves irradically
Until the inverter is turned off completely, either via remote or on the front of unit it will draw power, it goes into standby mode. Waiting for a load. Depending on the remote you have, if you have on they turn off differently. A link remote or basic.
Aug 04, 2008 | Xantrex Technology Heart Freedom 20 12...
RCR312W problem
I believe the remote is losing its program. Have you tried to reprogram the remote?
Jul 09, 2008 | Televison & Video
Xantrex Technology Heart Freedom 20 12 Inverter Logo
210 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
