Question about Black & Decker Tools & Hardware - Others
What is the proper dept to drive nails - Black & Decker Tools & Hardware - Others
    Problem Solver:
  • 11 Answers
I set my nail guns to drive the nails just flush and then finish it with a nail set if you need to recess them. I find that you can set them deeper but it leaves an ugly mark from the drive hammer that needs to be puttied. The depth of drive will vary depending on the type of wood also. The nail will go in farther on pine versus oak even though the settings didn't change.
Posted on Jun 26, 2009
94 park ave has personal choice feature allowing owner to select how vehicle responds to key fob lock button. Horn only, lights only, both horn and lights, silent. How you access the programming.
The easiest way to do this is to go to a dealer. Go to the front desk and nail down a salesman. He should get it fixed for you going to the service dept. It you go to the Service dept first they will want to charge you.
Apr 05, 2016 | Cars & Trucks
Where to find non-marring bumper for arrow et 200 nail brad gun part number 2815
The non-marring bumper for the ET200 nail gun is Part #2815. Send a note together with a check for $1.50 plus $1.00 S&H to Parts/Service Dept., Arrow Fastener Co., 271 Mayhill St., Saddle Brook, NJ 07663.
Mar 26, 2013 | Arrow Heavy Duty Nail Master Electric Brad...
I have a porter cable roofing nailer model # RN175 that does not advance the nails everytime what causes this?
Some causes, in order of probability:
Roofing nailers get a lot of tar build up on them, especially around the nose safety and nail feed pawl area. Cleaning off this buildup will usually take care of most problems with roofing nailers.
On the side of the gun away from the side you load the nails on there is a small cylinder with a piston inside that attaches to the feeder pawl. If air isn't getting to the piston or the piston's o-ring or spring is damaged, it won't cycle properly to advance the nails.
If the driver doesn't retract fully, the next nail won't be able to advance properly for the next shot. This can be caused by o-rings in the head that are worn or out of their proper place.
Oct 06, 2012 | Air Tools & Compressors
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
Hitachi nail gun,piston/nail push rod wont retract after pushing nail (stays protruding out of gun so the remaining nails stay underneath it
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
Oct 25, 2010 | Hitachi Tools & Hardware - Others
I work for a Fire Dept. in Vermont and we use the FC350A air nailer for building shores and other wooden support stuctures for our Urban Search and Rescue team. FEMA engineers say we have to use round...
Your nailer will only use clip head. Model FR350a looks similar however is designed for full round head. Take your gun to a large fastener company that deals in mainly construction industry nails/nailers and talk to the manager about purchasing nails for future events tell him your issue with FEMA. I'll bet that you could exchange your nailer for little no cost to the department for a round head type. They usually have plenty of used, trade-in and unclaimed guns. Good luck
Sep 26, 2010 | Porter Cable Cable No. FR350A Rnd Head...
Feed issues
This is usually caused by a dirty nailer. If you don't have the instructions on how to clean it you can download them from Porter Cable.
Jun 11, 2010 | Porter Cable 23GA Pin Nailer Kit
2 nails shoot at the same time
It could be just from using poorly clipped or collated nails. I have noticed that with some cheaper nails, the clipped heads are not all lined up properly. If a nail has rotated slightly during the collation proccess, the unclipped portion of the nail head protrudes over the previous nail in the clip. This causes the heads of two nails to be struck at once. Another problem I've encountered is collation wire that doesn't shear off with each nail. An ever lengthening strand of wire protrudes into the nail chamber and eventually the driver snags this wire as it drives a nail. This jerks the clip forward forcefully forcing more than one nail into the chamber or causing the next nails in line to rotate slightly, thus exposing the unclipped portion of the nail heads to the driver.
Mar 13, 2010 | Tools & Hardware - Others
Paslode im250 f-16 only able to drive 2 nails .
Bad Fuel cell!!! New cyliders now have expire date on bottom of cannister. If old will not fire properly. Put new fuel cell in should be fine.
Feb 21, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Tools & Hardware - Others Logo
70 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
