Question about Harley Davidson 426290 AM/FM Radio
2005 Ultra Classic CB transmits fine, does not receive at all . Replaced headset and cables, no luck.
  • 4 Answers
Have someone check your SWR readings (using a SWR meter) on the antenna. This should give you some information on reception.
Posted on Aug 29, 2009
1998 ultra classic am/fm/cb radio works good except cb it receives excellent but wont transmit
More than likely the "Final Power Output Transistor" has been fried due to a bad antenna or no antenna on the radio when someone tried to use it.
If you know how to solder you can find a replacement transistor at Digi-Key, Mouser or JDR-Micro Devices.
Its a fairly common problem and easy to fix. good luck
Dennis
Aug 21, 2017 | Radio Communications
Cobra 29 ltd classic year 2004. rf gain problems.
Put SWR meter between your antenna and output, test wave length receive/transmit, might need a ground plane or center loaded stick.
Could be transceiver relay, try clicking mic fast, it should click out as fast as you key the mic.
Oct 26, 2016 | Cobra Radio Communications
2005 HD ELECTRA GLIDE ULTRA CLASSIC ANTENNA REPLACEMENT WHICH IS CB AND WHICH IS RADIO NEED INSTRUCTIONS
YOUR CB IS ON THE RIGHT AND RADIO ON LEFT AS YOU ARE STANDING AT THE REAR OF BIKE LOOKING TO FRONT HOPE THIS HELPS YOU
May 25, 2011 | 2005 Harley Davidson FLHTCUI Electra Glide...
I can transmit but sometimes it won't receive. I put on a new cable today & and a new ant. last week (classic 29)
Watch your meter and if the needle is moving but you can't hear anyone then try a different microphone. The wire for receive might be broken intermittently.
Jun 15, 2010 | Cobra 29 LTD CB Radio
2001 Ultra CB radio does not transmit. It receives fine. When you key the mike, the CB radio display (squelch) goes blank, headset sidetone is very weak.
hi the radio internall will have a driver and final transistor these are for the output signal or tx. you might find that the final transistor is faulty and needs replacing these fail due to incorrect swr or tuning of the antenna or cable / connector shorts. dont over look a bad microphone connection wiring on either end and internally on the ptt switch
most common driver is 2sc2166 and 2sc1969 for 27mhz amm & ssb
Apr 21, 2009 | Harley Davidson 426290 AM/FM Radio
Won't receive audio or any noise with squelch all the way left
Perhaps a faulty connector on your coax cable. Get it fixed or replaced you coax cable with a new one.
Mar 24, 2009 | Cobra 19 Ultra II CB Radio
Cobra 29 LTD Classic not transmitting or receiving
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Dec 05, 2008 | Cobra 29 LTD CB Radio
Harley Davidson 426290 AM/FM Radio Logo
204 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
