Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
That sould not happen, the condener fan should blow enough air over the pan to take of the waterl. Make sure your coils under your refrigertor are clean. You heard it filling? The only thing fills is the ice maker . I do not have much information. Is this a top mount, freezer on the top or a side by side
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Check freezer... for Frost build up and if Fan is blowing,
Check condenser... To make sure clean, and the fan is blowing (by compressor),
Check recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
YOU CAN TRY turning FREEZER CONTROL
To A WARMER FREEZER SETTING Allowing.. MORE AIR.. to refrigertor side
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing,
make sure u didnt turn up freezer control cutting air supply to refrigertor side
should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
