Question about SanDisk Sansa e250 MP3 Player
Music won't go pass 116 files!
I have a sansa e250, and when i seem to sync in music, it ALWAYS says... unable to create a directory space blah blah blah.
ive tried formatting the damn thing and still dosnt seem to work.
please help =]
thank you
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
HOW CAN I SYNC MUSIC TO MY SANSA E250..?
To sync music you have to first open the Rhapsody music player (If you don't have Rhapsody you have to download it fom the Sansa disk or you cannot add music). From there you can drag the songs you want from your library onto the icon in the list on the left that says "Sansa e250". On that screen there is a bar at the bottom that tells you how much space is left on your Sansa.
Hope this helps!
Jun 05, 2009 | SanDisk Sansa e250 MP3 Player
Cannot Copy Music
u want to convert the song into mp3format using real player.
Sep 18, 2008 | SanDisk Sansa m250 MP3 Player
My sansa e250 wouldnt format!!!
You go to Start, Which is at the bottom right of your screen, then you click music, then you click what kind of mp3 player, or Ipod you have. There you have it
Jun 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa
From initial appearances, it would seem that you are running out of disk space with your Sansa e250. Should this have happened, there is a strong possibility that the filing system would also have been corrupted. The best would be to reformat and/or perhaps even to re-install the firmware. This is so as to start fresh/anew.
Incidentally, computerrep, anoother resident expert is with Sansa/Sandisk, you may have better luck with his able assistance. In a similar concern, he has posted this solution.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | SanDisk Sansa e250 MP3 Player
Missing music
Try formating the player. I know mine did the same thing and it had corrupted files on it. So, I formatted it and seemed to work fine. Be sure to back up your music files.
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Unreadable files for Sansa e250
Don't worry, there's a solution.
You have to run what's called "Check Disk."
  1. Switch the sansa player into MSC usb mode in the settings under "USB Settings".
  2. Then plug it into your PC and goto my computer.
  3. Then Right click the player's icon and goto properties
  4. Then there should be tabs on the top of the box that pops up. Click "tools"
  5. Then there is an area that says area-checking with a button that says "Check Now..."
  6. A box pops up; Click both option boxes and press start.
  7. Then exit out of all the boxes and safely remove the player.
  8. Unplug player and let it restart.
WARNING: Sometimes it will make files "disappear", but still use space. In that case you will have to format it and put the music back on. It all depends on how "corrupted" the files were. If your files disappear, reply stating so and I will help you out with that if you don't know how to format.
Thank you and please respond with any comments or more questions.
-John-
Feb 28, 2008 | SanDisk Sansa e250 MP3 Player
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
Can not view my music files on my laptop (but can on my desktop)
Get the latest firmware upgrade - this player wasn't originally designed with WMP 11 in mind. Also, make sure the laptop has the folders "My Documents" and "My Music" on it - this is primarily where WMP reads from.
Dec 06, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa e250
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
I can't put songs on my Sansa Sandisk e250....
Hey to get music onto the Sansa e250R you have to plug the Sansa into the computer. Next go to mycomputer. Then onen ethier sansa or Removable Disk(F:). Then take the songs you want and drag them on to the white space under photos and vidos and all that other files. DO NOT PUT IT IN A FILE.
Jan 27, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
