Question about HP PhotoSmart 7960 InkJet Printer
My photosmart 7960 does not print the magenta color at all. I've cleaned the carts, primed the carts, replaced the carts with original HPs. Still no magenta color. Every other color is perfect. Is there firmware available for this printe? Any ideas?
  • gtcurd Jun 26, 2009
    Thanks for the response. It was the first thing I checked. I beleive it's the firmware on the printer.
    We've had a lot of storms lately maybe it was lighting.
    Thanks
    Brigadier General:
  • 3,006 Answers
I've got two 7960's running and there are no firmware updates. I've also found them to be highly reliable and so far (touch wood) they've been unaffected by thunderstorms.
I think that your problem is probably due to a bit of dirt on one of the cartridge contacts, often this is caused by using third party carts which have tried to copy HP's "protective tape" with one which can leave a sticky residue. Even HP's tape sometimes does so but it's very rare.
Turn the printer on and open the lid, wait for the cartridge docking station to retract and remove the tricolour 57 cartridge and you'll see three double rows of contacts behind.
With the lid open and the cartridge removed, remove the power socket to the printer from the wall outlet. Leave the printer for ten minutes or so and have a cup of coffee. Afterwards, return to it armed with an anti-static wrist strap earthed to a suitable point, a piece of thin card or stiff paper wide enough to fit under all three carts and a pencil with an eraser tip (with plenty of rubber left above the metal ferrule) and some cotton buds/q-tips.
Slip the card beneath the carts, if possible smear the upper surface with a little Pritt-Stick or similar adhesive first but it's not essential. make sure you're still earthed and use the eraser tip on the central row of contacts. The card will catch the debris (and stick to it if there's adhesive). If you see anything other than pristine contacts then they need cleaning. Do not use a hard (ink) eraser as they sometimes contain metallic particles and the residue that they leave is abrasive.
When you think you're done, use the cotton buds to gently sweep any remaining debris onto the card. Carefully withdraw the card and refit the 57 cart, but clean the cart contacts first in the same way before doing so. Reconnect the printer power supply and test the printer.
Hopefully it should now work, if not repeat the process but finish off with lint free tissue on the end of your fingertip moistened with isopropyl alcohol, and repeat on the cart..
If the cartridge doesn't work after this then the flexible pcb inside the printer is damaged If you can dismantle the printer and trace each track then you *might* be lucky enough to find the break and be able to bridge it with electrically conductive paint . If you can't then your printer will need a new flexi pcb, but they're not cheap to replace and you may find afterwards that the fault is still elsewhere due to something like the possible static damage you mentioned or just an unlucky random failure.
If you lived in the UK I'd let you have one of the three others I have stashed in the loft, new and unused. I only bought them as unsold stock disposals because it was cheaper than buying replacement sets of cartridges!
I hope this has helped you, and only ask in return that you return the favour by rating my answer.
Posted on Jul 10, 2009
    Sergeant:
    Champion:
  • 233 Answers
Yes, I believe that you didn't take off the long peice of of plastic which covers the cart.
If not, try shaking the color. then put it on again.
Hope this helps!!
Posted on Jun 26, 2009
Hp 7960 prints in all green
it sounds like another color could be low or empty
Nov 20, 2012 | HP PhotoSmart 7960 InkJet Printer
HP Photosmart 2610 all-in-one printer. I've replaced my color and black carts. with refilled ones. My color ink drained all over the bottom of the inside of the printer. I am no longer going to be...
You can use a degreasing spray or methyl alcohol to clean up the residual ink. Use a brush to clean and wipe and BLOW using a hair dryer to fully dry up the residue.
Make sure that there is no dirt at the terminals, clean and set with original cartridges from HP.
Now if there is errors then you must disconnect printer, uninstall then install the driver, connect printer when prompted and print a test page.
Sep 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 3110 does not print magenta or light magenta
i think you need to download a perfect drivers
i hpe i can solve your problem
Sep 02, 2009 | HP PhotoSmart 7960 InkJet Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Printer printing out wrong color. i have cleaned the cartridges several times, checked to make certain tape is off. How do I configure the printer to allow me to have access to the printer service to...
Print a test page. if that is ok, then it could be the color profile you have selected. Also, you can make your own test pattern of Yellow, magenta, and cyan. (use mspaint and make 3 colored bars, a black bar, and a white background). Print that, and see if all 3 colors and black are printing. If one color is not printing (ie, yellow for example) then there is an issue with that printer head on that cartridge. If you are recycling the carts, then that cart needs replaced.
Aug 28, 2009 | HP Photosmart C3180 All-In-One InkJet...
Black and white printing not working
sounds like its a expired ink issue. on alot of the hp photosmart printers the ink has a expirey date on the carts the best solution would be to contact hp and chances are they will send you free carts if your ink has been expired. when a black ink is almost out most of the time it trys to draw ink from the color carts mixing to make the appropriate color.
but you can also try the following.
See the instructions for
calibrating a print cartridge in
the Care and Maintenance
section of the HP Photosmart
Printer Help.
Aug 11, 2008 | HP PhotoSmart 7960 InkJet Printer
HP Deskjet 932C printer will only print in magenta
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet.
Jul 03, 2008 | HP DeskJet 932c InkJet Printer
Is this a free service?
Thoughts of a tec....Heads is part of cartridge on Hp's, Refilling is not recommended causes more issues than it is worth. There is not anything else that deals with printing in these machine except for the cartridge, so you problem is definatly in carts, recommend replace with the real deal.
Cleaning can be done via print driver, user manual is available from HP's web
Cheers
S.
Dec 30, 2007 | HP Photosmart 2610 All-In-One InkJet...
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
HP PhotoSmart 7960 InkJet Printer Logo
407 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
