Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer wont print HP OFFICEJET 6110 all-in-one
Printer worked fine UNTIL I put in a new colour cartridge without removing the tab, AND then trying to print a photo, by following the Wizard steps, and it downloaded an updated version of the printer program. in fact, at this stage I CANT remember exactly what I did to try to solve the problem!!! Problem is, the printer is NOT printing. When I try to print a photo, the computer tells me to connect the printer to the computer. It IS connected. I´ve switched off the computer, unplugged the printer, switched all on again. nothing helped.
I URGENTLY need to have it working PLEASE
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1-if you are in any application, word, windows etc... click on
Is the printer there hp 6110 ( if not reinstall driver)
does it have a checmark next to it? no, then right click
go to properties
set as default
put your mouse over printer, does it say ready? no, check connection or change cable.
Good luck
Posted on Nov 08, 2007
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cant print and im getting an error message
This generally means that the cartridge is empty or defective and needs to be replaced with a new one.
Sep 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 won't accept new cartridges.
Check these HP FAQs for your printer:
Also see, at the end of each one, the links to related printing problems.
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 not printing. Can't get out of "align cartridge"mode.
printer problem call up hp at 1-800-474-6836 and ask them for an upgraded printer which you will get at 50-60% cheaper than the original and its a factory new printer.But it is definitly not free.
What you have right now is a hardware problem and the printer is dying so change it fast while this offer is available
May 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Remove & check cartridge message
What you could try do is to remove both cartridges, close cartridges cover
Unplug printer for awhile, at least 30 minutes
Plug in printer and wait until printer stop
Reinstall both cartridges
This is to let the printer reset and do a new installation of ink cartridges
Feb 20, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
54 people viewed this question
Ben Johnson
