Question about Peg Perego Cub Cadet Tractor
Looking to see if 12.5 HP briggs and stratton mount holes are the same as 16 HP briggs and stratton can these engeins be fitted across different lawn tractor platforms i.e will the Craftsman 12.5 B/S fit on the Cub Cadet that had a 16 HP B/S Thank you
  • karl higgins Sep 24, 2009
    Cub Cadet engine
    16HP
    Model 311777
    Type 0120-E1
    Code 000119ZE
    Body---
    Family YBSXS-5012VP 27453
    Model 13AE698G595 Code 1A280I30150
    Craftman
    Model 2897A7
    Type 0179-01
    Code 9605207A
    Tractor Model 917-256451
    Serial 061896B 008328
    Hope this helps
    Thanks
  • Chuck
    Chuck May 11, 2010
    Need the model and type numbers off both engines
  • 389 Answers
The bolt patterns are the same, space should not be a problem going from the OHV to the flat head. The only other thing you should do is physically measure both crankshaft extensions (the part that sticks out the bottom of the engine) making sure that they are the same length, diameter and bolt hole is the same.
The muffler might be a concern depending on how the Cub muffler was oriented.
As in any engine swap there may or may not be some modifications you have to do ie: throttle and choke arrangement, fuel line routing, alternator capacity and wiring etc. so I will say yes it SHOULD fit without modifying the tractor and/or frame and it can "be fitted across different lawn tractor platforms"
Posted on Sep 24, 2009
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
Where can i get a repair manual for Briggs and Stratton Champion 35 Lawnmower
contact Briggs and Stratton USA, they will have them. I got one 12 months ago for a different (old) model.
Apr 22, 2015 | Briggs & Stratton Garden
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Oct 01, 2014 | Briggs & Stratton Garden
Snapper mower 42 inch with brigg stratton vanguard 16 hp v twin engine lopes when not under load
I would start by cleaning the air filter and the spark plug, or replace both if they are old.
Aug 08, 2014 | Briggs & Stratton Garden
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Fitted new coil to briggs and straton 16 twin but have no spark
unplug the wire that comes from the tractor then check for spark if you do then stat by checking he safety switches
Mar 30, 2012 | Briggs & Stratton Garden
Briggs and Stratton Governor Linkage problem
The easiest thing for you to do is look at any 12.5-19hp Briggs single cylinder engine that's on just about any riding mower.. They all have the same set-up.
Jun 10, 2009 | Garden
Peg Perego Cub Cadet Tractor Logo
416 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
