Question about Samsung SP-R4232 42 in. Plasma HDTV
Samsung spr4232 screen problem
Good day all i have a samsung spr4232 the picture quality has worked great up until a week ago the picture is great for about 20 min then sudenly only plays picture on 1/2 and somtimes on 1/4 on the right side of the screen after tv is off for a couple hours its fine again for 20-30 min then does it again we had the geek squad out and they said they were going to change a panel for 600.00 but said they cant garranty it well fix it so any how after a 160 service call for recieving nothing i would realy appreciate some advise or input..thank you
techman
  • 3130 Answers
SOURCE: Little red dots
The driver board is going bad it sounds like and if you do not call up and get it fixed under warranty, as it should still be under a warranty, then its going to be a nice hefty repair bill. Good Luck Ps Please dont forget to rate this thread
Posted on Oct 19, 2006
phoenixcomm
  • 18 Answers
SOURCE: samsung hlp5674w
not blub you do get light ie a picture it sound like your video processor has a heat problem,
alias, you can not repair this you self, Hope its still under the warranty. You got to take it to the repair man... Soory
Posted on Feb 12, 2008
Ajkill
  • 2035 Answers
SOURCE: I purchased a Samsung 50"DLP
This is the problem with tv main board ,I would suggest a Sumsung authorized reapir tech do the repair.
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing procedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 12, 2008
  • 11 Answers
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
tvtek
  • 1284 Answers
SOURCE: I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
Posted on Sep 10, 2009
I had to factory reboot tab and now I cant get passed the Samsung account screen...
Hi Nicholas!
Take the phone to your service provider or an authorized Samsung dealer.
Here is a link to Samsung Support.
Good Luck
JP
Samsung
Sep 18, 2015 | Samsung Cell Phones
Green snow now black screen
It could be the logic but also the Y main. Probably should let a pro take a look it could be an expensive guess. Either circuit will cost you a few hundred. Good Luck
Jun 24, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Picture keeps alternating between HDMI1 "blank screen" and cable
try the lead in another slot and even another lead, if problem persists demand an engineer comes out.
Jul 31, 2009 | Philips 42PFL5603D 42 in. LCD HDTV
I need instructions on how to use my camera.It is ViviCam 3.6.3.2, 2.0 Mega Pixels. DC 2330 & 116L038C006363 on the bottom of the camera.
i just bought a samsung camera ,S1065 3 weeks ago. It was working very well until three days ago when i tried to change the battery. it comes on, take a picture and switches off by itself. what could be the problem?
Sep 06, 2008 | Vivitar Cameras
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung HL-p4674 RB
Sir, Pull up the on screen menu and make sure the unit is set to display 1080i or 720p instead of 480i. This may be the issue. Good Luck
Jun 04, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Samsung SP-R4232 42 in. Plasma HDTV Logo
99 people viewed this question
Jerry Greenberg
Jerry Greenberg
