Question about LG Washing Machines
Stains appearing on clothes after washing with LG washer
I'm having the same problem with my LB front loader. It appears on my husband's shirts, but will wash out. I've just unloaded my white sheets and the oil stains are all over the sheets! I so was tired of it that I googled the problem. It's been happening on and off. Probably can't see it on the dark clothes. Only notice on the whites.  It's like a left over residue. I always use the extra rinse cycle too and still get it. I'm calling the LG service.
SOURCE: Whirlpool front loader staining..
i have the same washer and i am some times perplexed about stain that appear after washing> i always blamed colors tranfer from other items .I'll keep a closer eye and see if i can find any more. does your washer have any oders that bother you mine does. for the price i feel cheated
Posted on Mar 15, 2008
huuum
  • 750 Answers
SOURCE: Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
Posted on Sep 26, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Grey Stains on my whites
Need ot check the main seal and the main bearing. You can do this by accessing the rear of the unit.
Posted on Feb 13, 2009
  • 41 Answers
SOURCE: I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Posted on Sep 03, 2009
  • 13 Answers
SOURCE: Random brown stains in random loads of laundry
Hi from Australia
Ok the problem with your washing machine is that there is grease and oil stuck in the machine and the oil will dribble out when you run the machine on a different cycle if you rince with cold water then the oil stays in there and the hot water lets a little bit out as it is stuck in the pipes of your machine ok the first thing is run an empty load on full hot water even the rince cycle with 1 cup of bleach nothing else let that go through the long cycle then do the same again with 1 cup of white vinger and 1/2 cup citric acid which you should be able to get over there or baking soda try that it will clean your machine and your pipes it is great way to keep it all clean by the time you have done this you should not have any brown stains
Have a great weekend
Posted on Jan 22, 2010
My washing machine makes marks on everything
LG WM2101HW 4.0 cu.ft. Washer Stains clothes ruining ...
www.fixya.com > ... > LG > LG WM2101HW 4.0 cu.ft. Washer
... stains out with anything and they are ruining numerous items of clothing. ... stainson light objects ie making white marks on light blue clothes ruining these ... by greasestains from their front loader Kenmore. .... remove the agitator from a ...
Oct 19, 2015 | LG WM2101HW Front Load Washer, White, 4.0...
I am frequently getting brownish-tan crescent shaped stains/marks/burns? on mostly light colored cotton clothes. The stripes are 2-4 inches by 1/4-1/2 inch. I am not sure if they are coming from the...
Hi , Could be oil from the drum bearings if its noisy during spin. Could also be residue from the drain/ Sink disconnect and check drain hose is it very dirty...........
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whites are dingy. Random stains appear on my husband's dress shirts that weren't there when I put them in the wash. We have a water softener; don't know if that plays into the problems. Please help!
Put washer through a clean cycle with bleach only. Check to be sure you are using HE soap. Check the bellows(door seal) make sure it is not jamming clothes.
Oct 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag puts holes in clothes
try to change the soap and the washing cycle to delicate,good luck
Sep 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
OIl stains on clothes with front loading LG washer
ftr loader washers do not have any oil, my guess would be you are using fabric softner . that can stain clothes. dilute with water, they are very concentraded. or your dispenser may not be working properly and not releasing softner at the proper time.i would run a clean cycle through it. meaning set on a hot wash- regular cycle no clothes and run wirth bleach in bleach disenser. do this every other month to keep washer clean hope this helps. make sure its not happening in the dryer , the dryer has frt and rear seals that go bad and start leaving marks on clothes and catching them in beteween the tub.
Sep 16, 2009 | LG WM-2032H Front Load Washer
Spots on clothes after washing
Put another filter on before the washer. Try to find out if it is in the hot water or the cold. If it is the cold try a filter. If it is the hot, replace your hot water tank.
Jun 06, 2009 | LG WM0642H
Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
Sep 28, 2008 | LG WM2487H Front Load Washer
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
195 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
