Question about ASUS Eee PC 701 Notebook
Key 4/$ can't work - ASUS Eee PC 701 Notebook
  • 2,404 Answers
Try blowing the dust and dirt off of the keyboard and especially off of the area on the 4/$ key.
Also if you can take the key off and wipe it down with a damp cloth then that may take away any dirt that coult be affecting the main board underneath that key.
If that doesn't work then the keyaboard is defective and you need to replace it.
Posted on Jun 26, 2009
I'm trying to multiply 1 by 10 to the negative power of 4. Can't seem to find out how to make the 10^-4 work.
Press 1 EE +/- 4
EE is the key just above the 7 key, +/- is the key just to the right of the decimal point key. Don't use the - key, that's for subtraction not negation.
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
No serial key. need a serial key.
If your talking about windows then ill give you some serials
It is prohibited giving away serials but use it at your own risk
Windows XP
Serials : HB3C7-99PXJ-FVVC9-K9CCR-2F4DQ
GKFHD-F8X3X-TCYPP-22JTX-3PK23
TFVVF-9XXT6-W7C89-B8HC4-GDGM6
DQYRT-C4P7G-7RB37-B9FVG-RY6JD
TVTQM-VWJRF-W3QPC-3VJ8F-G6296
P7Y92-R3T6Y-MWVCX-84FTF-MYB7G
Please tell me when the serials dont work anymore :)
Windows XP Home Edition :
HXK38-VX8DT-7D86X-R6G64-G82JP
Windows XP Professional Edition:
DXWB7-4P7TC-TVXHW-8F4JB-3TR2M
> Windows 7 SERIALS
Keys:
ID-Key: 434488-jvgkvljk
ID-Key: 625598-vbvazrva
ID-Key: 825211-qilqufqq
ID-Key: 893868-xysdvkxd
ID-Key: 584450-vjqwdsvw
ID-Key: 948663-fokqqzfq
ID-Key: 790363-lioqsjlq
ID-Key: 501509-atqmovam
ID-Key: 639608-zgzbxhzb
ID-Key: 426814-vohojevo
Jan 26, 2011 | Computers & Internet
Printer reading H 4 and will not print
PRESS THE CLEAR KEY -THEN PRESS EXPOSE MODE KEY - PRESS CLEAR KEY AGIAN - PRESS EXPOSE MODE KEY. THIS GETS YOU INTO SIMUALTION MODE. PRESS 1 then 4 THEN HIT START.. if it does not clear the heat lamp could b bad or thermal fuse or thermistor
Mar 31, 2010 | Toshiba e-STUDIO 120 Laser Printer
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Programming
When
How
Jan 25, 2010 | 2004 Honda Accord
Need to reset the key fob after replacing the battery
You should not have to reset the key fob after a battery replacement. The signal from the key fob stays the same and is programed to the reciever.
If the key fob needs to be reprogrammed then follow these steps.
1. Have all key fobs with you during programming.
2. Sit in the vehicle with all doors closed.
3. Lock all doors using the Lock/Unlock switch on the door.
4. Insert and withdraw the ignition key 7 to 9 times within 10 seconds (do not turn the key, just insert and withdraw).
5. The 4 way flasher indicator on the dash should flash once or twice.
6. Insert the ignition key and turn it on (key on, engine off).
7. Press any button on one remote and the 4 way flasher indicator on the dash should flash once.
8. If you have more key fobs to program use the Lock/Unlock button on the door to unlock the doors and then lock the doors.
9. Press any button on the next key fob and the 4 way flasher indicator on the dash should flash once.
10. Repeat if you have more key fobs. Only 5 can be programmed.
11. To exit, simply turn of the igniton and remove the ignition key.
12. Unlock the doors using the Lock/Unlock switch on the door and exit the vehicle.
13. Make sure the window is down when testing remotes in case you leave the keys inside.
14. Close all doors and test all remotes that were programmed.
Do not skip any steps or the process will not work.
If the 4 way flasher indicator does not work when inserting the key, you will need to start the process from the begining. If it still does not work the receiver may be your problem.
If the 4 way flasher indicator does not flash when pressing any button on the key fob then the key fob is the problem (dead battery or defective remote)
Dec 18, 2009 | 2002 Nissan Xterra
Instructions for programing kwikset lock
-Insert the functioning key (current working key)
-Turn 1/4 turn clockwise
-Insert Programming tool (goes in the real small slot) until you hear the click.
-Remove the Program tool
-Remove the functioning key
-Insert the new key
-Turn back 1/4 turn counter-clockwise.
-The new key should work with the lock now and the old one should not.
Oct 18, 2009 | Kwikset Locks & Locksmithing
I bought 2 kwikset deadbolts.The first one worked out fine.The second one I turn the original key by accident.Now neither key will work.Is there a way to rekey my original key.
put the 'dummy key' that came in with it, turn it a 1/4 turn right, put smart key in, pull out smart key. pull out the key and insert the key that you would have as a desired key and turn left 1/4. thats it!!!!!!
Jul 20, 2009 | Kwikset Locks & Locksmithing
I got lost my biohazard 4 cd key which runs on pc..howiget free
Here You can have it.... From my cd.. I dont mine helping out... It has hapen to me a few times... enjoy!
bh82220691119281
Dec 07, 2008 | Roxio Easy CD & DVD Creator 6...
ASUS Eee PC 701 Notebook Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
