HEATER BLOWER MOTOR
Its
faulty blower motor resistor. The low and medium speed on blower motor is
controlled by resistor and its actual speed is high. So because resistor is not
working, blower motors actual speed which is high is working.
It
can be faulty blower motor or faulty blower motor resistor. Get the blower
motor inspected. If it's faulty it has to be replaced.
For
blower motor testing and replacing, check the link below: ----
http://repairhelpcenter.blogspot.in/2012/02/blower-motor-replacing-for-all-vehicles.html
These will help.
Thanks.
Get the blower motor re-inspected. If its faulty it has to be replaced.
For
blower motor testing and replacing, check the link below:----
These will help.
Thanks.
It
motor inspected.If its faulty it has to be replaced.
For
blower motor testing and replacing,check the link below:----
Blower motor Testing/replacing for all vehicles?
These will help.
Thanks.
HEATER BLOWER MOTOR
It
For
These will help.
Thanks.
Also
more help solutions recommended. Click the link below :---
Blower motor replacing for all vehicles?
----------Blower
motor Resistor shorting problem?
http://schematicsdiagram.blogspot.com/2011/12/blower-motor-resistor-shorting-problem.html
--------This will help.Thanks.
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
