Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
I havea -1year old Oxygen Vacuum and the powerhead just quit.
I can't find a reset button on the power head I have, although I have
used one at work and it has one?
  • 3 Answers
The vacuum you have is made by eureka (cheap)
the original electrolux today is called aerus
Posted on Jul 15, 2009
  • AerusGuy
    AerusGuy Mar 08, 2018
    No, the original Electrolux is AB Electrolux of Sweden (begun in 1919)--that used to own The Eureka Company. Aerus LLC (begun in 1924) is the former U.S. subsidiary of AB Electrolux. From 2004 until 2016, most of its vacuum cleaners were also made by The Eureka Company.
I was very lucky. It fixed it's self somehow.
Posted on Jun 26, 2009
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Dec 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The powerhead brush died. The vacuum works just fine, but the brush doesn't.
there could be 2 reasons for this problem.
one) the powerhead is dead legit as in there is no power coming to it or the motor is actually dead.
2) something jammed in the brush and popped the reset button. The reset button is a red button located as your looking at the back of the powerhead on the right side. Usually a red square. Push it and it SHOULD start up again.
That being said, if you have done the reset button and it still does not work, that unit I beleive has either a 2 or 5 year warranty (cannot remember dont have the documentation in front of me) and if it is still covered under warranty for you, take it to your closest Vacuum repair shop. Do take the hose and powerhead with the cannister unit.
good luck
Nov 06, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
No power when its turned on
There was a (common cause) power arc during the swap (while running the vacuum).
The fuse located under the grey clipped-on plate of the canister is blown. The fuse is soldered-on the board and would need to be changed (board or fuse). Not "user friendly" zone. Warranty? Smart if they designed a breaker button instead of a fuse here...
Rick
Mar 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Kenmore whispertone model 11620412003
I am getting suction to the power mate, but the mate doesn't
work. The belt seem fine, but the light and beater doesen.t
go on. Tried the reset - no result. Thanks
Dec 29, 2007 | Vacuums
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Oct 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux power nozzle not working
the powerhead gets its power through a connector adjacent to the hose connection to the vacuum end. there's two wires embedded in the hose which make its way to the handle, pipe and powerhead. take apart the handle and see if you can read continuity from one end to the handle switch.
Aug 06, 2007 | Electrolux Guardian Bagged Canister Vacuum
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
514 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
