Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
My Kitchen Aid Freestanding Ice maker Keeps going into clean mode
The unit is 9 years old . . still makes ice . . .as long as it stays on . . .
Model "Superba"
  • rwburke Jun 26, 2009
    While operating normally in the on position the ice maker switches to clean mode which normaly requires a physical prompt by pushing "clean cycle" button.
    President:
  • 2,187 Answers
You may have a stuck clean button. Check out also if the button has become wet on the inside and out. The moisture may have made the contact which completes the circuit as if your were the one who pushed it.
Thanks
Posted on Jun 26, 2009
  • 351 Answers
I need more info dont quiet understand what you mean... will not charge this session intill you are happy or you can save your money and call me direct... whirlpoolpartssurplus.com ask for mark
Kitchen aid clean light keeps on red and machine doesnot make ice
This unit has a max ice run counter in the software, so after 500 cycles this unit requires you to run a clean cycle completely. After this is completed, it will rest and allow you to produce ice again, use nickel safe cleaner to do this or just run clean cycle without cleaner if unit is already clean. This cycle should last about an hour or so. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jun 10, 2014 | KitchenAid KUIS18NNT 18" Automatic Ice...
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
My Kitchen Aid freestanding ice maker keeps going into Clean mode. How do I prevent this?
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for: http://www.repairclinic.com/KitchenAid-Ice-Maker-Parts
RepairClinic.com
logonobyline3.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
1,010 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
