I need to reboot my Vx670 credit card terminal .
Push F2 and F4 at the same time.
Enter the system password z66831. (You get the z by pressing keys 1, alpha, alpha) choose restart. Opionally remove the power cord then press and hold the red cancel key for ten seconds. Wait for the shut down. Then press and hold the green enter button until it turns back on.
What I do is not reccomended. Remove the battery and the power cable. Then replace the battery and power cable.
SOURCE: key selection error VX670 TAMPER LOG F5
Tamper is cause by the bad internal/system battery that need to be replaced or you a bad plastic case which triggers the internal sensor on. We need to reload the Verifone Software to clear the tamper error. If you still need help you can call (775) 358-2922 ask for Randy. Thank you. http://freshpoint.org
SOURCE: Verifone vx670 problem. for some reason everytime
What did you do to the vx670 before you had that stuck screen on loading problem??
