Question about Samsung LN-R237W 23 in. LCD Television
Hello, My Samsung LN-R237W television has developed a problem after two years. The right-hand half of the screen is now white with fine vertical stripes. The vertical stripes change from multicolored to black. The problem cleared up once, but it is back and is now constant. The left hand side of the screen is perfect. The problem is present using HDMI, component, and RF sources as well as during menu operations. Is there a menu fix or an inexpensive repair? Thank you. Tim
    Sergeant:
  • Samsung Expert
  • 330 Answers
It looks like a defective LCD panel, not worth to fix it.
Posted on May 27, 2017
Cerfer39
  • 709 Answers
SOURCE: Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Posted on Oct 10, 2007
  • 71 Answers
SOURCE: DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Posted on Dec 10, 2007
SOURCE: hp r4252 white vertical stripe on left side, 5 in wide
is there any way to disable the light going to that part of the screen? ie: make the stripe black instead of white?
Posted on Feb 02, 2008
Williston
  • 7 Answers
SOURCE: Samsung HLR5667W lamp replace
The Problem you all are describing is a faulty light tunnel assembly it is common on most DLP projector sets.
Something I would not recommend attempting if you don't have the skills, It involves taking apart the optical system of the engine, you could have it repaired from an authorized service center for under $400.00.
Posted on Feb 24, 2008
skotkolr
  • 558 Answers
SOURCE: Image Retention
burn in is not supposed to occur on an lcd tv, however I have an lcd from Proview that leaves images on the polymer layer the white horizontal address bar is the most prominent. if I leave the monitor off for about 3 days the images disappear, this may or may not help you, if Samsung has created a ticket on this issue you may well receive a prepaid shipping label to return the tv for repair.
Posted on May 27, 2008
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
I have a line running thru my tv
vertical(up/down) or horizontal(left/right)? color/white? when you tap on the top of your tv does the line go back to a full screen? could be a makers defect.
Aug 22, 2011 | Samsung LN-S2651D 26 in. LCD Television
I have a 40" Samsung
Call Samsung (1-800-726-7864)about the problem. They are aware of theproblem and offer a 1 time free repair. Therepair is generally done in your home. Samsungdid tell me that they even take care of the bill outside your warranty. I hopethis helps
Apr 19, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
My Samsung 23 inch LCD tv works fine for 25 minutes then the screem starts jumping..
There is a Anynet Setting under the input tab. It has to be on the right setting or the picture Jumps after 20-25 minute. Once I adjusted it to the right setting it stopped jumping and it now works Perfect. Would nt have figured it out if I wouldnt have been messing around with it as a last chance deal.
Dec 27, 2009 | Samsung LN-R237W 23 in. LCD Television
32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Mar 18, 2009 | Samsung LN-R237W 23 in. LCD Television
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Replace Main Board?
If he is familiar with soldering, try opening up the set and reseating all of the connectors and cables. Then look for poor solder connections and resolder any that appear "bad". Update this with the results.
Dan
Jul 29, 2008 | Samsung LN-R237W 23 in. LCD Television
Samsung LN-R237W 23 in. LCD Television Logo
71 people viewed this question
Jerry Greenberg
Jerry Greenberg
